Size of mp4 for 60 minute video? (720p)
Posted by Gilles Gagnon on May 2, 2017 at 3:00 pmHi folks,
I’m working on a project using SVP12 which will result in a 60 minute video (approximate ). This .mp4 file will be copied onto hundreds of USB sticks for sale/distribution.
I have 4 questions:
1. Which render template should I use to ensure the best render?
2. How large will this file be?
3. Would a 4GB USB stick suffice?
4. Is there a way to calculate the file’s size given the 720p and video length?As you can see… I need to be absolutely certain that the sticks we’re purchasing in advance will have sufficient capacity.
Thanks in advance for any advice.
GillesGilles
Graham Bernard replied 9 years, 4 months ago 9 Members · 19 Replies -
Graham Bernard
May 2, 2017 at 3:34 pmAs a rough starting point for your research, the higher the BITRATE the larger the file. What you haven’t said is what/where the File will be played on and shown monitor.
720p simply indicates one of the dimensions of the Frame and that it will be Progressive.
Being helpful here, why not try a suck n see attitude? I’ve calculated MPG for DVDs using a BitRate calculator, must be one for MP4s?
Does any of this help?
* Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Gilles Gagnon
May 2, 2017 at 3:44 pmThanks Graham, I appreciate your input.
It will be mainly displayed using home computers. Getting answers to my four questions will greatly help me in figuring this out. I’m happy to try but having prior knowledge will help with efficiency. At this point I lack data, hence my specific question ☺
Cheers,
GillesGilles
John Norton
May 2, 2017 at 4:26 pmMaybe just render out 6 minutes, see what size it is then multiply by 10 to get an idea of flash memory size. Take more than one 6 minute sample if necessary. 20mb/s is a good starting point for good enough quality.
László Kovács
May 2, 2017 at 5:56 pmAlso be careful with filesize limits. A new pendrive is most probably factory formatted to fat32, which can’t hold files bigger than 4GB, even if the drive itself is 16 or 32 GB…
You can of course format to exfat, which does not have this limit.
Just be aware.
20Mbps for 60 minutes will result approximately 9GB (plus the audio!), so for that you’ll need 16GB drives, or lower bitrate to 14Mbps, so a 8GB drive seems to be enough (and almost full).
For 720p 14Mbps is still qutie good, I think.Best regards
László Kovács
Gilles Gagnon
May 2, 2017 at 6:09 pmThanks John!
I’ll wait and see if someone else pipes in.
Surely someone must know the answer to my 4 questions :)…. I didn’t think the questions were arcane lol. The answers will also likely help others.
GGilles
Mike Kujbida
May 2, 2017 at 7:21 pmGilles, I use Handbrake when rendering 1920 x1080 files and got just under 2 hr videos down to under 5 gigs so no problem getting 1 hr to under 4 gigs. Hope that helps.
Don’t forget to format the USB sticks in NTFS to overcome the size limit. -
Mike Kujbida
May 2, 2017 at 7:27 pmForgot to mention that I use the Internet AVC/AAC 1920 x1080 preset. Adjust as needed for your requirements.
Gilles Gagnon
May 2, 2017 at 9:17 pmHey Mike!
Great to see you again!Thanks for your 2 posts. very helpful.
So the “Internet” setting is of good quality…not only for “internet purposes” only?
… and 8000-16000 Mbps will suffice? (this is the default setting for the Internet 720p template)
Gilles
George Dean
May 2, 2017 at 10:14 pmHi Gilles,
A 60 minute 1080p video in Vegas Pro 13, rendered to 720p29.970fps using the MainConcept AVC template VBR 16,000,000 max 8,000,000 avg, single pass yielded a 4.1 gig file. The size is going to vary dependent on the content both video and audio, as well as, the codec used.
I agree with Mike, using Handbrake is going to provide a better quality, smaller file size and faster render times.
If you are not familiar with FrameServing, you may want to do a search on Vegas2Handbrake. Full instructions are available on the net and everything you need is free to download and setup. Once you have installed the file and the script setup, it will send your project from Vegas to Handbrake via FrameServing using only a couple mouse clicks, and Handbrake will do the rendering for you.
Also a Google search will provide several file size calculators for mp4 files, all of which that I have tried were way off!!
Hope this helps.
Best Regards…..George
Eric Clinch
May 3, 2017 at 1:28 amI’m not sure that reformatting a usb stick to NTFS is a good idea. Even if it does overcome the 2gb file limit. My understanding is that they are FAT so they can be read by Windows, Apple & Linux as Apple cannot read NTFS. But maybe things have changed. Also my three year old Panasonic TV will (according to the User Guide) only read FAT16 and FAT32 sticks.
