Activity Forums Adobe After Effects Expressions Single random number on x axis
  • Single random number on x axis
    Posted by Criis Daw on June 5, 2015 at 11:01 am
    Hi all.
    i have hit a dead end and need your help.
    i am trying to place objects on a the x axis
    i want each objects position to be a little to the right of the one to the left of it.
    I have been using this expession
    thisComp.layer(index-1).transform.xPosition+50
    so each object is 50 pixels on from its neighbour. I like to use this expression as it allow my to change the order of the objects with out having to alter position information.
    Right but i would like to add some variation into it. rather than adding 50 I would like to add a value of between 20 and 50. And i can t for the life of my figure it out. Any help very much appreciated
    Criis Daw replied 11 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 5, 2015 at 1:59 pm
    Try it this way:
    seedRandom(index,true);
    offset = random(20,50);
    thisComp.layer(index-1).transform.xPosition+offset
    Dan
  • Criis Daw
    June 5, 2015 at 2:03 pm
    oh you make it look so easy !
    thanks dan
