Single clips in a sequence not exporting
I have an edited sequence in Premiere Pro CS4 and I’m trying to export the sequence, however one of the clips in the timeline isn’t exporting when I try to export the whole sequence, I just get black.
I have 6 layers/video channels and the clip that isn’t exporting is on the 3rd video channel. All the other clips on this channel export fine, as do all the other clips in the sequence. The clip plays back rendered off the timeline with no problems.
I even tried changing the clip and exporting the sequence again however that section of the video will still not export.
If anyone has some suggestions as to why this is happening and how I can fix it I would be VERY grateful!
Martin.
