Activity › Forums › Panasonic Cameras › Set up time lapse on Panasonic AG-HVX200
Posted by Thomas Mazzarella on January 28, 2011 at 3:07 pmI have a Panasonic AG-HVX200 and looking to record a time lapse sequence.
Can anyone tell me what settings I should turn on in the camera?Thomas Mazzarella
Joseph Warren replied 13 years, 6 months ago 7 Members · 16 Replies -
Chris Tompkins
January 28, 2011 at 4:14 pm -
Thomas Mazzarella
January 28, 2011 at 7:40 pmChris, when I get to the interval time screen, it says 2f to the right, should I be able to go into that and change that 2f to something else? It’s no allowing me to do that. Have any ideas?
Thomas Mazzarella
Chris Tompkins
January 28, 2011 at 7:58 pmWell the 2f is the default, if you cannot change that then you need to make sure you are set up correctly to interval record.
Did you select interval record?
Are you in 720 record mode?Chris Tompkins
Video Atlanta LLC -
Thomas Mazzarella
January 28, 2011 at 8:10 pmI am in 720p, and do I go under recording set up first? then listed is interval time. is this correct?
Thomas Mazzarella
Chris Tompkins
January 28, 2011 at 9:09 pmI believe so yes, I don’t have the cam in front of me.
Choose interval recording.Chris Tompkins
Video Atlanta LLC -
Thomas Mazzarella
January 28, 2011 at 11:00 pmI still cannot get to that setting. Is there a step by step process somewhere, the manual is no real help.
Thomas Mazzarella
Dave Neyman
January 29, 2011 at 1:50 amDo the following:
1. Scene File – Set Operation Type to Video Camera
5. Recording Setup – Set Recording Format to 720P/60P
5. Recording Setup – Set Rec Function to Interval
5. Recording Setup – Set Interval Time
You need to do the math to figure out the best interval time. It depends on how fast you want it to play back.
Thomas Mazzarella
January 29, 2011 at 2:29 amInterval is set at 2f in blue color and cannot change it. where do I go from there?
Thomas Mazzarella
Dave Neyman
January 29, 2011 at 2:59 amYou got me. I’m not sure why yours is not working. Mine works fine. My menus is as follows:
Rec Format
480i Record Mode
Rec Function
One Shot Time
Interval Time
Etc.The menu selection you want is INTERVAL TIME. Is it possible that you are looking at ONE SHOT TIME?
Andrew Milner
August 28, 2011 at 11:54 amThe above information was very helpful. Would you set your camera to auto iris and shutter?
