Activity Forums Adobe After Effects Roto brush propagating when it shouldn’t be
  • Roto brush propagating when it shouldn’t be
    Posted by Zak Ray on August 20, 2010 at 3:30 am
    Hi all,
    Another roto brush question (thanks for all your patience to this point). Roto brush seems to be propagating too often for no apparent reason; for example, if I’m roto brushing a 500 frame clip, get to frame 250, and switch comps briefly, it will need to repropagate everything when I get back– without my having changed anything.
    As great as roto brush is, it’s far from perfect, and repropagating for no reason can cause it to undo touchup work that I’ve already done. Anyone have a similar experience?
    Zak Ray replied 15 years, 9 months ago 2 Members · 2 Replies
  • Todd Kopriva
    August 20, 2010 at 4:28 am
    The Roto Brush propagation information is stored in RAM. If you’re starving your system of RAM and switch to another context, the Roto Brush cache information will have to get dumped from RAM so that your other context can be loaded.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Zak Ray
    August 20, 2010 at 12:06 pm
    Thanks, Todd!
