Activity Forums Adobe After Effects Robot-like Movement
  • Robot-like Movement
    Posted by Wasef El-kharouf on April 12, 2010 at 3:42 am
    I shot some footage with someone dressed in a robot costume and needless to say, despite their efforts, their movement looks very “unrobot-like”. I was thinking I would just remove some frames between key movement positions but I was hoping there might be a way I can tailor the footage in After Effects to make the robot a little more rigid. I’m still quite new to After Effects so any suggestions?
    Wasef El-kharouf replied 16 years, 4 months ago 4 Members · 5 Replies
  • Ben Rollason
    April 12, 2010 at 12:48 pm
    What you’re describing… spatial intervention so to speak sounds unnecessarily complicated.
    Time remapping is what you want. I would guess you can make a very convincing robot effect with a bit of time remapping.
    -Ben.
    vfx.benrollason.com
  • Steve Roberts
    April 12, 2010 at 2:31 pm
    Effect>time>posterize time, set to a low frame rate?
    Or yes, you could use Time Remapping, with hold keyframes at the ends of each movement. Look for tutorials on it, but keep this in mind: the value of the time remapping effect at any given time is the frame of video currently being displayed. So, if you’re looking at the time remapping graph, a flat plateau indicates a freeze-frame, because the value (displayed frame) is not changing. A slope up and to the right indicates forward playback, and down to the right indicates reversed playback.
    Be prepared for a lot of experimentation here until you get it right. If you need to start over, just delete time remapping from the layer and start over by applying it again.
  • Ben Rollason
    April 12, 2010 at 2:39 pm
    I generally find it’s best to feel your way with time-remapping footage.
    The graph isn’t as useful as say with position or scale, because you need to multiply the speed of the time remap by the speed of the movement inherent in the clip.
    Steve’s right…. experimentation!
    -Ben.
    vfx.benrollason.com
  • Heath Alseike
    April 12, 2010 at 3:44 pm
    Time remapping can be tricky if you are new to after effects and take a long time to get just right. Also that is a good way to ease motion and for a robot you don’t really want that. I would just freeze for a a few frames at the end of each move he makes. Or if you really want to practice animation, find a good frame to freeze and roto all of his limbs and animate him yourself.
  • Wasef El-kharouf
    April 12, 2010 at 8:12 pm
    Thanks for all the advice, guys. Very much appreciated!
