Activity Forums Apple Final Cut Pro Legacy Rippling audio keyframes
  • Rippling audio keyframes
    Posted by Ernie Santella on January 31, 2006 at 10:00 pm
    I have a long music track that goes under a bunch of testimonials and B-roll. Right now, the music dips under each testimonial. I have to add a couple of additional testimonials.
    Ky question is… I don’t want to have to re-do all my audio keyframes to follow the video that is now shifted later. Is it possible to ripple or move all the audio keyframes?
    Ernie Santella
    Santella Film/Video Productions
    http://www.santellaproductions.com
    Gilbert Hangartner replied 18 years, 8 months ago 2 Members · 2 Replies
  • Gilbert Hangartner
    January 17, 2008 at 11:35 am
    Very interesting question. It’s bothering me since a long time. Did you find a solution in between? I’m sure it must be, and it would really save a lot of tedious work!
    Gilbert
    January 17, 2008 at 1:46 pm
    Well, at least I now found I work-around, inspired from a post on copy keyframes (see below, don’t know how to link)
    1. Duplicate the audio-clip, in which you want to ripple the keyframes.
    2. Ripple the audio content in the copy by the inverse amount of frames
    3. Copy the original audio-clip
    4. Insert attributes->”level”, deactivated the “scale length” checkbox
    5. Ripple the duplicated audio clip back, and there you are.
    => seems comlicated, but once you’re used to the twisted logic, it’s very fast!
    hope this helps somebody!
    Gilbert
