Activity Forums Adobe Illustrator Retro Graphics
  • Vincent Rosati
    June 1, 2010 at 4:19 pm
    Create your object with the Rectangle or Ellipse tool.
    Then with it selected, Effect/Distort../Zig-Zag.
    Adjust the settings as necessary and hit OK.
    If you need to edit the shape further, to get it ‘just right’, you can Object/Expand Appearance.
    Now you have the shape that you can fill with whatever or use as a mask.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
