Activity › Forums › Apple Final Cut Pro › Resolution for Aspect Ratio(s)
Posted by Thomas Frank on April 12, 2015 at 6:41 pmHi,
anybody know or aware where to find the resolution for the following aspect ratio for 4K?
1.85:1 Widescreen
2.35:1 Anamorphic
2.40.:1 Cinema
2.55:1 Cinema Scope
2.75:1 Ultra Panavision 70
3.00:1 Super Wide
4:00:1 PolyvisionThanks!
Thomas Frank replied 11 years, 5 months ago 3 Members · 10 Replies -
Jeremy Garchow
April 12, 2015 at 9:40 pmTake whatever 4k width your using, and divide it by the ratio
If you’re using 3840 and need 1.85:1 then take 3840 and divide by 1.85.
Alternatively, you can take a pixel height and multiply by 1.85.
It’s easiest to take width as that will fit into a standard pixel count (with letterbox). If you used height, you run out of width in standard frame sizes.
Thomas Frank
April 13, 2015 at 12:54 pmThanks Jeremy
I will give it a try….
Don’t understand what you mean with…
[Jeremy Garchow] “It’s easiest to take width as that will fit into a standard pixel count (with letterbox). If you used height, you run out of width in standard frame sizes.”
Thomas Frank
April 13, 2015 at 2:39 pmSo I tried the method deciding the pixels through the aspect ratio.
4096 / 1,90 but I get 2155 which the pixels size actual 4096 X 2160 is for 1.90:1???
Jeremy Garchow
April 13, 2015 at 2:52 pm[Thomas Frank] “Don’t understand what you mean with…
[Jeremy Garchow] “It’s easiest to take width as that will fit into a standard pixel count (with letterbox). If you used height, you run out of width in standard frame sizes.””
If you went with full height, you’d have to “squeeze” the remains pixels in to the frame (think of pushing the left and right width together and smushing them in to the frame to fit.
If you are using 4096×2160 as the 4k standard, then if you use 2160 as the height, and need a 1.9 aspect ratio, you’d come up with a with of (2160*1.9) 4104 pixels. You have two choices, you can either crop off the remaining pixel width (4104-4096 = 8, which in this case isn’t a big deal) or you squeeze the 8 pixels in to a 4096 frame size.
But, if you use the width as the boundary, then you simply end up with a letterbox. 4096/1.9 = 2156, so your frame size would be 4096×2156.
What are you trying to do, exactly?
Jeremy Garchow
April 13, 2015 at 2:54 pm[Thomas Frank] “So I tried the method deciding the pixels through the aspect ratio.
4096 / 1,90 but I get 2155 which the pixels size actual 4096 X 2160 is for 1.90:1???”
That’s right. This is, of course, calculating for square pixels. It does not take in to account any anamorphic squeeze.
What is your source material?
Thomas Frank
April 13, 2015 at 3:00 pmI’am trying to make aspect ratio borders in Photoshop in a 4096 x 2160 resolution.
Also would need one for a 3840 by 2160 resolution. -
Jeremy Garchow
April 13, 2015 at 3:06 pmThen take 4096 and divide by the aspect ratio, and that gives you the height.
4096/1.85 = 2214, frame size – 4096 x 2214
4096/2.35 = 1743, frame size = 4096 x 1753
etc…
Gary Adcock
April 13, 2015 at 3:19 pm[Jeremy Garchow] “Then take 4096 and divide by the aspect ratio, and that gives you the height.”
It does not quite work that way as the aspect ratios were devised for Film standards and not digital .
A more accurate chart is a https://www.digital-intermediate.co.uk/resolution/resolutionaspect.htm
Currently the best reference book available by ASC member Dave Stump
https://www.amazon.com/Digital-Cinematography-Fundamentals-Techniques-Workflows/dp/0240817915gary adcock
Studio37Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, ILFollow my blog at https://www.garyadcock.com
Or follow me on Twitter
@garyadcock -
Jeremy Garchow
April 13, 2015 at 3:23 pm[gary adcock] “It does not quite work that way as the aspect ratios were devised for Film standards and not digital .”
Sure, but it’s really close, especially for photoshop guides and square pixels.
Thomas Frank
April 14, 2015 at 9:33 amThanks Jeremy, but when do I know where to add extra pixels and not?
