Activity Forums VEGAS Pro Rendering Nightmare
  • Rendering Nightmare
    Posted by Sabrina Watson on August 2, 2008 at 6:07 am
    I have spent the last twelve hours or so viewing the boards–looking for an answer to my problem and I can not seem to understand why this is happening.
    I’m known for making fan-videos. I work with VOB files in Sony Vegas. Once in a while during production, the frames will jerk a bit, but when I render it in any format (such as avi, mpg, etc.) it works just fine. There is no jerking of the clip.
    Now I’ve finally shot my own clips with my video camera. It’s a flash drive camera that copies the files onto my computer in a second. The clips come through as avi files.
    I have used clips for one shorter video when I wanted to test out of my camera and nothing was the matter. Now I am suffering.
    I have tried everything imaginable and I still can not seem to get certain clips/frames in my video to stop jerking.
    I’ve taken the velocity off and done ‘ctrl’ while dragging the clip to the right. I’ve combined all the media into one line. I’ve used things I never knew Sony Vegas even had so far. It still is happening and I am about to go crazy.
    This video is the last video to my portfolio before I send it out. It’s my first video where my idea came from scratch and it is not considered a fan music video.
    All I want is help. I’ve tried to render it in avi, mp4, mp3, etc. I’ve tried to use divx codecs and a few others that seemed to have come with Sony Vegas and still the frames jerk for a least ten or more clips–and it’s only a 4 minute video. It isn’t a long video at all. I’ve even tried to mess with the frame rate even though I have no idea how that sort of thing works just yet.
    I’m not sure if it’s the actual file itself, but it will play fine during the making of the video and if I open it up and just play the file–but when I render it with any format it starts acting up.
    I am at a total loss–and it’s enough to make me cry. I have worked so hard on this video and I have spent the entire day on it. If anyone is willing to help me if they can, I will thank you for the rest of my life.
    Sabrina Watson replied 18 years, 1 month ago 4 Members · 46 Replies
  • 46 Replies
  • Theo Van laar
    August 2, 2008 at 10:11 am
    You say that your video is transferred to the PC as an AVI file. But do you know what kind of avi file? If not, you can check this with a program called GSPOT.
    Theo
  • John Rofrano
    August 2, 2008 at 2:40 pm
    GSpot will tell you a lot about the video but for now, let’s see what Vegas thinks:
    Right-click an event with a “jerky” video. Select Properties and then look on the Media tab. What does it say for:
    Format: ?
    Attributes: ?
    Frame rate: ?
    Field order: ?
    Pixel aspect ratio: ?
    Also what is the make and model of the camera that shot the video. If the camera has more than one media type (i.e., mp4, mov, mpg, etc) which type did you use when you shot it? If yuo don’t know go check the camera settings and see. You probably haven’t changed them since the shoot.
    Could you post a small sample of this “jerky” video on the web so we can see exactly what you mean when you say “jerky”?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Sabrina Watson
    August 2, 2008 at 3:09 pm
    Stream Properties: Video 1
    Attributes: 720×480, 00:00:36;27
    Format: DivX 5.2.1 Codec
    Frame Rate: 29.970
    Field Order: Lower field first
    Pixel aspect ratio: 0.9191 (NTSC DV)
    Alpha Channel: none
    My camera is a: Samsung SC-MX10 Black ~ Digital Flash Memory Camcorder w/ 34x Optical Zoom.
    I’m not so good at finding out about the camera yet, but I know that when I connect the usb port the files get onto my computer in avi files. Also the video setting shows 16:9 and for resolution it shows 720x480i. I have that one with a little p after it and a 352×250 with a p after it too.
    I’m not sure if I’ll be able to get a clip of the video up. I do have my own domain, but I use free webspace, but I’ll see if I can maybe upload a clip of it on my photobucket for the time being.
    This is the link to the camera: https://www.walmart.com/catalog/product.do?product_id=9188680 just in case it shows more information than I know about it yet. It’s my first camcorder.
  • John Rofrano
    August 2, 2008 at 8:36 pm
    Hmmm… sometimes Vegas can be very “twitchy” about the editing files encoded with the DivX codec. That might be the source of the problem. I just encoded a file with DivX 6 and brought it back into Vegas and rendered it out again and it was smooth. I only have DivX 6 so I’m not sure if DivX 5 is the problem. Make sure you have the latest DivX codec on your system.
    You can test if DivX is the problem by rendering one of the files in a different format outside of Vegas and see if you still have the issue. You could use a free tool like VirtualDub to render one of the files using the HuffYUV codec (also free and lossless). If this works then DivX is the problem.
    You could also try opening a new project, place just one file on the timeline and render it to NTSC DV AVI in Vegas. Then see if that render is OK. Maybe it’s a combination of DivX and something you are using in the project.
    Cool little camera though. 😉
    ~jr
  • Sabrina Watson
    August 2, 2008 at 10:26 pm
    Thank you for replying back.
    Okay–here’s another problem. I just opened up my project to try what you told me (I also got the most up-to-date version of DivX) and now my video clips are there, but they won’t play. They’re just blank. The only thing that will play in my project is the music and the text.
    How can I get it back now? It doesn’t even show red–it’s just blank. They are there, but the actual videos aren’t.
  • John Rofrano
    August 3, 2008 at 4:18 am
    It sounds like the latest version of DivX might have something to do with this. Do the clips play in the DivX player? You need to get them out of the DivX format. In addition to VirtualDub there is also a converter called “Super (c)” that will pretty much convert any video to any format. You might want to download Super and just render them to uncompressed AVI. They will be huge but they will work for this project.
    I would also contact Samsung and ask them what software they recommend for editing the video from that camera. DivX is really a final delivery format and not something you want to be editing.
    You could also see if the DivX installer set a System Restore point in which you could go back to before it was installed. Or try uninstalling and re-installing the previous version that you had.
    ~jr
  • Sabrina Watson
    August 3, 2008 at 4:50 am
    is uncompressed AVI different than regular AVI? Because the camera put the clips on my computer in avi format.
    It says the “media is offline” for a bunch of them when I went back a few hours ago to see.
    But if I install the new version of DivX won’t I be in the same position with my video? I downloaded it in hopes it would fix the problem.
    I’m getting a little confused now. Let me see if I understand this correctly…
    1. Download VirtualDub and Super
    What do I do with both of those programs?
    If I download those two programs can I keep DivX on my compute or will I still need to uninstall it?
    BTW, your site is awesome. I always wondered if there was a way to do a split screen in vegas. I didn’t even think there was a masking tool. Very cool!
  • John Rofrano
    August 3, 2008 at 2:32 pm
    AVI is just a file format. It’s a container for video (like a paper bag that you can put things into). AVI files can use different CODEC’s (e.g., DivX, DV, MJPEG, etc.). A CODEC is a Coder / DECoder combination. It encodes your video with compression to make it smaller and decodes the compression to get the original video back. Uncompressed video is simply video that doesn’t use a CODEC. This makes it extreme large because it is not compressed but it also makes it extremely compatible because there is no CODEC involved. So you can create an AVI file with any CODEC or you can just place the uncompressed video into it.
    The reason I recommended making an uncompressed AVI is because the DivX codec seems to be causing a problem so removing the codec from the equation eliminates that problem. Huffyuv is another codec that you can use if the uncompressed AVI files are too large.
    That’s not good. “Media off-line” means that Vegas cannot find the files (or cannot read the files at all)
    So you downloaded it but did not install it? I thought you installed DivX 6 and that’s when all the media turned black? Was that not what happened?
    Sorry if I confused you. I was giving you multiple options to try and we probably should just take one option at a time.
    1. Download VirtualDub and install it.
    2. Open VirtualDub and drag and drop one of your camera videos onto it (you should now see the video in VirtualDub)
    3. Click File | Save as AVI… or press F7
    4. Give it a name and click Save
    You should now have an uncompressed AVI file that you can drag and drop onto the Vegas timeline and render out and see if you still have the “jerking”.
    If this works, the next step is to install Huffyuv and use that as a codec so that the AVI files are not so large. Then there is an extra step in VirtualDub of selecting the Huffyuv codec before saving (Video | Compression… or Ctrl+P and select Huffyuv v2.1.1)
    You absolutely keep DivX on your computer. DivX is the codec that these programs need to decode your video. Without DivX installed you cannot use your videos at all.
    Thank you. I wish I had more time to put up tutorials but I’m glad you found it useful.
    ~jr
  • Sabrina Watson
    August 3, 2008 at 4:38 pm
    Sorry I made a mistake. I did download DivX 6.8 and I also installed it. That is when the media could not be found.
    I downloaded VirtualDub. I remember using this a few years ago.
    I’m getting an error when I try to click and drag one of my clips from my camera. It says:
    Couldn’t locate decompresser for format ‘SEDG’ (unknown).
    VirtualDub requires a video for windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable.
    I have no idea what hat means.
    I just wanted to ask a quick question before I forget, does the media being offline mean that if/when it does get back online I will have to start my video over from scratch anyway?
  • John Rofrano
    August 3, 2008 at 5:49 pm
    OK, I did some searching on the web and found that these Samsung videos only work with DivX 5 by default, but I have a fix. More on that later…
    > I’m getting an error when I try to click and drag one of my clips from my camera. It says: Couldn’t locate decompresser for format ‘SEDG’ (unknown)…I have no idea what hat means.
    It means we are getting closer to the real problem! ;-D
    AVI files have a four character flag that tells the application which codec to use. This flag is called the “FourCC”. Your files have a fourcc of ‘SEDG’. VirtualDub and Vegas cannot find the codec that is associated with ‘SEDG’ on your system.
    Here’s where it gets interesting. DivX 5 registers itself as supporting this fourcc but DivX 6 does not. There is a simple utility called the “FourCC Changer” that can change this. Download this utility. It doesn’t even need to be installed (just unzipped). Open one of your AVI files in this utility and you’ll see both entry fields show SEDG. Just change them both to DIVX and press Apply. Now drop this file into Vegas and the file should play correctly.
    You will have to do this for all of the files that come from this camera. I would make backups of all of the files before you change any of them, just for safe keeping.
    I found a sample of a Samsung camera AVI file on the web and I downloaded it and it would not playback in Vegas just like yours. Then I changed the fourcc to DIVX and it played and rendered fine so I’m very confident that this will work for you.
    Once again, I would contact Samsung and ask them how they recommend that you edit this strange format. Maybe they have some conversion software or their own codec that you were supposed to install?
    No. Once you change the fourcc of all the files, they should all be recognized as on-line and working properly.
    The BIG question is… after all this, does this solve your render problem?
    ~jr
Page 1 of 5
