Activity Forums Apple Final Cut Pro Legacy Render Jumps Clip to Different Frames
  • Render Jumps Clip to Different Frames
    Posted by Martin Nelson on May 3, 2011 at 9:58 pm
    There may be to many steps in this process to figure out where the problem lies, but maybe this issue will sound familiar to someone so here goes.
    I wanted to capture some computer screen moves and cut them into my show. I used iShowU to record the screen images. As I wasn’t certain what I would need for my final resolution and wanting the best possible image, I recorded Uncompressed 8-bit.
    I then used mpeg streamclip to convert the QT to DV 720×480 for the low rez cut of the show. I then imported and cut the clip into my sequence. The timing was off so I had to extract some parts and extend some static screens, not by changing their speed, but by cutting them in more than once.
    Here’s the problem: when I render the clips the frames jump to different timings. I’ve played with this endlessly, but I can’t figure out how to get a rendered version of what I’m really trying to achieve.
    I know that description is pretty hard to follow; I’m banking on someone recognizing the issue through the mud and having the answer I need.
    Anybody?
    Martin
    2 x 2.26 Ghz Quad-Core Intel Xeon
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
    Avid Media Composer 4.0.2.20
    Paul Dickin replied 15 years, 4 months ago 3 Members · 3 Replies
  • Dan Monro
    May 6, 2011 at 2:40 am
    Hey Martin,
    It happened to me once; never figured out why. I eventually figured out what the offset was and purposefully slid it to the wrong frame so that it was correct when rendered.
    Have you tried exporting it as a new self-contained, same-as-source QT? Then make your cuts and see if the re-wrap fixes the problem?
    Last ditch, throw it to a tape and re-ingest.
    Maybe a greater mind can actually solve your problem. Hope so.
    Good luck,
    D
    Dan Monro
    FCP, Avid, AfterFX, Atlanta
    MacBook Pro 2.53 GHz Intel Core i5 4 GB ram
    Mac OS X 10.6.4
    NVIDIA GeForce GT 330M
    Final Cut Pro 7 Quicktime 7.6.6
    – OR –
    2 x 3.2 Quad Xeon; 16 GB ram
    Mac OS X 10.6.4
    NVIDIA Quadro FX 5600 Final Cut Pro 7.0.2 Quicktime 7.6.6
  • Martin Nelson
    May 6, 2011 at 3:46 am
    Yeah Dan, I figured out after posting that it was an exactly 20 frame offset and I forced it that way into what I wanted.
    I can’t remember (and don’t have fcp launched right now) if I tried to export/import the clip. I had tried to export the clip from a sequence and it, of course, wanted to render first.
    Another bug. Wonder if any of them get fixed in fxpx or if we just get a new interface and more bugs.
    Martin
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
  • Paul Dickin
    May 6, 2011 at 8:48 am
    Hi
    QuickTime, and video creation/screen-capture programs based on QT, can have frames of variable duration (= variable frame rate). This is incompatible with FCP’s need for a stable fixed frame rate.
    The best solution I’ve found is to use Cinema Tools to conform such video files to a proper frame rate before transcoding for import into FCP.
    If using MPEG Streamclip always set an Export frame rate, never let it use the current frame rate.
    The biggest change with FCP X appears to be the EOL’ing of QuickTime and all its foibles in favour of a much more robust metadata-database based successor AVFoundation.
