Activity › Forums › Adobe After Effects Expressions › removing expression…but keeping the current position
  • removing expression…but keeping the current position
    Posted by Michael Duff on November 27, 2007 at 2:39 am
    hi all … i’ve applied an expression to a number of solids to give them a random Z-position … i’ve manually set the X and Y. The expression takes a random seed from the index value…
    now I have all the solids where I like them and want them to stay where they are … but when I add new layers it changes the random seed and therefore changes the position …. if I just turn off the expression the solid moves back to its original Z position …. is there a way for me to disable the expression and keep the solid in its current position?
    does this make sense?
    Michael Duff –
    Bearcage Productions, Australia
    Trent Armstrong replied 18 years, 9 months ago 3 Members · 3 Replies
  • Dan Ebberts
    November 27, 2007 at 3:22 am
    Animation > Keyframe Assistants > Convert Expression to Keyframes might be your best bet.
    Or, you could apply a bunch of sliders to a single null, use your random expression on each slider, link the sliders to the z positions of your other layers, and always keep the null at the top of the layer stack.
    Dan
  • Michael Duff
    November 27, 2007 at 4:31 am
    thanks Dan, the keyframe assistant should do the trick
    Cheers
    Michael Duff –
  • Trent Armstrong
    December 10, 2007 at 11:05 pm
    A good trick here is to set your comp to be ONE frame long and then do the Convert to Keyframes trick. That gives a fast result and only one keyframe to delete for each layer.
    Trent
