Activity › Forums › Sony Cameras › Reliable link to EX1 firmware update??
Mark steven replied 2 years, 3 months ago 87 Members · 287 Replies
Julian Masters
October 10, 2015 at 3:17 pmHi Josh.
I sent a dropbox link earlier on.
Let me know if for some reason you didn’t get it.Julian.
Clifford Steinberg
November 10, 2015 at 4:35 pmSo happy I found this thread! I am also trying to update my EX1 firmware. My email is: cliff.steinberg@yahoo.com
Thank you so much!
Cliff Steinberg
Rent Com, Inc.
http://www.rentcom.com
Chicago -
James Zaiter
November 21, 2015 at 12:25 amHi Julian
I recently upgraded my ex1 from 1.26 to 1.30 and now the SDI out does not work.
I have checked that firewire is disabled and checked with multiple monitors – the output is dead.
Is there any way i can try and reload 1.26 as it was working with that version.
I have tried local sony agents but no luck.
regards
james -
Julian Masters
November 21, 2015 at 8:09 amHi James.
If you send me an email address I can send you a Dropbox link to the firmware files.
I haven’t got an EX1 here to look at, but it may be worth noting down your important settings and then doing a system reset.Regards,
Julian.
James Zaiter
November 21, 2015 at 8:14 amThanks Julian
My email address is nono2212000@yahoo.com.au
Do you have the procedure for reloading firmware as the version up tool does not allow reflashing
regard
James -
James Zaiter
November 21, 2015 at 8:39 amThanks a million Julian
I have been searching everywhere for firmware and just couldn’t find anything other than 1.30.
Do you have a recommended procedure for reflashing.
I have read in the forums that i should reload 1.13 as it might not have been installed from a previous upgarde.
regards
james -
Julian Masters
November 21, 2015 at 8:44 amHi James.
I’ve sent a Dropbox link.
When you say reflashing, do you mean to the same version?
If it doesn’t let you go back to the previous version, the only thing I would suggest trying is maybe loading v1.14, as that has a different type of installer.Quite a few people in this thread have reloaded 1.05 and gone up from there with no (major) issues. The only problems I’ve read about is that the original installer only seems to work with older versions of windows.
It gets mentioned a couple of times in this thead … if you can find it 🙂Regards,
Julian.
James Zaiter
November 21, 2015 at 8:47 amThanks Julian
I will try your suggestion and let you know.
regards
James
