Activity › Forums › Sony Cameras › Reliable link to EX1 firmware update??
Mark steven replied 2 years, 3 months ago 87 Members · 287 Replies
Josselin Millecamps
June 15, 2015 at 5:28 pmHi,
After an issue on Firmware Update 1.30 for ZX1, do you know if it’s possible to go back / downgrade the firmware, the VersionUpTool.exe with 1.20 firmware version don’t accept to update with an older firmware….Tanks by advance for your help.
Best regards.
JosselinCTM Solutions .
Paris -
Julian Masters
June 15, 2015 at 8:57 pmHi Josselin.
I assume you mean an EX1 !What version did you upgrade from?
Most people on here jumped from around v1.05 up to v 1.20 or higher and then got error messages.
As far as I’m aware most/all of them downgraded back to 1.05, and then incrementally went up to higher versions.
If you need to go down to a low version post an email address and I can invite you onto my shared Dropbox folder. Each version has got install instrucions enclosed, and the install program changed slightly at v1.20Also, I’ve only got the Windows versions.
Regards,
Julian.
Josselin Millecamps
June 15, 2015 at 9:39 pmHi Julian,
First, thanks you very much for your quick reply.
yes I will downgrade for try to find my “audio” features…
My email is joss@ctmsolutions.comThanks by advance for your precious help !
Best regards
Josselin
Paris -
Josselin Millecamps
June 16, 2015 at 12:31 pmThanks a lot !
It’s working fine !Be carreful for users on Win 7 or 8 for a firmware downgrade, the previous application (previous 1.20 version) don’t working fine on 64Bits OS.
You can downgrade without issue using 32 OS.Best regards
Josselin -
Paul Kozinski
October 2, 2015 at 4:27 pmHi Julian,
You are indeed everyone’s saviour by the looks of it! Are you still able to share your Dropbox files? I’m currently on 1.11 and looking to go up!
paulokozinski (at) gmail.com -
Josh Hamman
October 8, 2015 at 11:50 pmHi Julian!
Sorry to dig up an old thread but, do you happen to still have those EX-1 firmware updates somewhere handy?
Or someone else here that got em from Julian?
Thanks so much!
Josh
Julian Masters
October 9, 2015 at 11:34 amHi Josh.
If you provide an email address I can send you a dropbox link.
Regards,Julian.
