Activity Forums Apple Final Cut Pro Legacy Regarding “I am absolutely amazed” post below
  • Regarding “I am absolutely amazed” post below
    Posted by Nick Toth on May 25, 2005 at 3:22 pm
    I found that setting field dominance to ‘none’ in the sequence settings made my problems with graphics go away. It had been set to “lower” in DV sequences.
    I am able to use “Best” mode and everything looks great so far.
    Joey Korenman replied 20 years, 11 months ago 4 Members · 5 Replies
  • Walter Biscardi
    May 25, 2005 at 4:08 pm
    [Nick Toth] “I found that setting field dominance to ‘none’ in the sequence settings made my problems with graphics go away. It had been set to “lower” in DV sequences.”
    Lower is the correct setting for NTSC DV or SD material. Using “none” will make the graphics look better on your computer screen, but not an NTSC monitor.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Nick Toth
    May 25, 2005 at 5:12 pm
    Hi Walter
    Actually, this is NTSC out through AJA IO to a Sony broadcast monitor. There is a major difference and everything looks much better with field dominance set to ‘none’.
  • Derek Woods
    May 26, 2005 at 12:41 am
    I think he’s right walter. I just had heart failure working on fcp 5 and my new g5. Picture were scaling at an unacceptable quality. changed dominance to NONE, closed project, opened new one and imported and scaled pic. Now its at FCP quality levels and a little better than 4.5 scaling.
  • Derek Woods
    May 26, 2005 at 12:50 am
    ps-its a broadcast monitor out from firewire camera
    g5 2.7-fcp5-qt7
  • Joey Korenman
    May 26, 2005 at 3:41 pm
    I’m having the same issue. Switching fields-dominance to none fixes the image quality problem. It’s a bug, it should get fixed soon enough.
    joey
