Activity Forums Adobe After Effects Expressions Ref Audio Amplitude from parent comp from inside nested comps
  • Ref Audio Amplitude from parent comp from inside nested comps
    Posted by Brian Mills on January 26, 2012 at 7:24 pm
    Hello all
    I have a project where i have an expression that uses audio amplitude to turn on lips during whistling. I have many different scenes I am setting up that are going to be there own comps.
    I want to use these comps on a main comp with the music reference. So that way if I move these nested comps around and the timing with the music will still trigger the lips to turn on to make it look like h=they are whistling with the song.
    Can i reference an audio amplitude layer on the main comp from inside the nested comps?
    Brian
    a = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
    if (a >.3) 100 else 0
    Brian Mills replied 14 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 26, 2012 at 7:34 pm
    Sure:
    a = comp(“Main Comp”).layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    Dan
  • Brian Mills
    January 26, 2012 at 9:05 pm
    Thanks again Dan!
