Activity Forums VEGAS Pro recording audio into Vegas
  • recording audio into Vegas
    Posted by Chuck Manly on May 16, 2010 at 8:27 pm
    I’m trying to record my cassette tapes and vinyl records to make CD’s.
    My current setup is this…
    cassette deck > PC Soundcard line in > Vegas Pro 8c
    I’m using Microsoft sound mapper (I think) and the only control I seem to have is a line in record level control from my motherboards software.
    Is it possible to enable Track FX like compressor or EQ during the recording process? So far one tape was too hot in sections and another was just all over the place. Can I get more control over the incoming analog audio using Vegas?
    If I need outboard equipment what do you recommend?
    I’d also like to record clients talking about their photos and be able to include that narration in a slideshow video. What is a good work flow for that?
    John Rofrano replied 16 years, 4 months ago 3 Members · 2 Replies
  • Bob Peterson
    May 16, 2010 at 9:51 pm
    I don’t think you can apply controls while recording, but that is a very good question. I control my input volume by running things through a preamp and a mixer. I can control volume from either one or by using both. I do need to make a test pass to get the volume set at a good level. BTW, I am recording via Sound Forge, so my volume meters are a bit more useful.
    For field recording, I use an M-Audio Microtrack 24/96 field recorder. It shows me when volume is loud enough by flashing a green light, and when volume is clipping by flashing a red light. I just have to keep the green light on, and the red light off. It records audio on a compact flash card, so it is a simple matter of copying a file to move a recording onto the computer.
  • John Rofrano
    May 17, 2010 at 11:39 pm
    Bob is right. If you want to pre-process the audio you will need hardware pre-processors placed before the audio enters your PC. All software recording is done raw with no processing at all.
    I would err on the side of setting your input lower because you can always make it louder in post, but once it is too loud and clips, the data is lost forever.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
