Activity › Forums › Apple Final Cut Pro Legacy › RealTime Playback Dissolves & 2nd track
Posted by Pete Sake on January 1, 2006 at 6:28 pmWere not getting real time dissolves or real time by adding a second track gets a red bar.
We are in Safe RT. Capture input AJAlo la: YPb Pr Betacam US DV/DVCPRO.
2 gigs of RAM on a G52.7 /FCP5/ Betacam 2800
How do I get RealTime Playback Dissolves & 2nd track?
Peter
Coming from a Media 100 backgroundPete Sake replied 20 years, 8 months ago 4 Members · 13 Replies -
Bouncing Account needs new email address
January 1, 2006 at 7:12 pmWhat kind of capture and timeline?
Uncompressed?
DV?What kind of Hard Drive(s)?
Internal?
External?
SCSI?
FW?
RAID? -
Frank Nolan
January 1, 2006 at 7:51 pmIt will depend on your sequence settings and the clip settings your are trying to put on the second track. Also you may want to try unlimited RT and playback set to dynamic.
Pete Sake
January 1, 2006 at 7:58 pmDont know how to find the uncompressed settings. Its set at DVCPRO50
I’m not a techy but I think the two 400 gig drives where raided internally they are fast for HD ready.
Hard drives / Internal Serial drives / SE-ST3400832AS SEAGATE DRIVE SATA2 400GB 7200 8MB Tempo-X SATA 4×4
https://www.g5drivebracket.com/We are in Safe RT.
2 gigs of RAM on a G52.7 /FCP5/ Betacam 2800Thanks
Peter -
Pete Sake
January 1, 2006 at 8:07 pmThanks I have an Orange render bar. But when I add two tracks I get a message saying turn off unlimited RT. I do that and get a red bar.
Somethings not right.
When I out put to video does FCP render?
Also when I print to video to record to Betcam 2800 do I have to manual press the Betacam to Record. The M100 does this automaticly.
Thanks.
Peter -
Pete Sake
January 1, 2006 at 8:41 pmMaybe this is the problem
Under Preferances- General-Limit real time video I’ve put in 200mb.
Any clues appreciated
Peter -
David Roth weiss
January 1, 2006 at 9:02 pmPeter,
May I ask, exactly why are you capturing Betacam as DV/DVCPro?
DRW
Pete Sake
January 1, 2006 at 9:40 pmI was told DVCpro was the best Codec. What would you sugest for BetcamSP
Oh and I’ve just got 2 gigs of RAM
Thanks for responding
Peter -
David Roth weiss
January 1, 2006 at 9:53 pmPeter,
I’m not certain how many hours you are trying to capture, but normally Betacam is captured at 8-bit uncompressed or, in an effort to save hard drive space, JPEG. I seem to remember having a similar discussion back a while ago. Are you capturing as DVPro because you’re intercutting with real DV?
DRW
Pete Sake
January 1, 2006 at 10:09 pmI just thought DVCPRO was the best codec. Motion JPEG B? Not sure what to do. Its just a short piece 3 min final edit and I’ve got loads of room. I’m not going to redigitize it later. So I want to bring it in at a high quality.
Peter
