Activity › Forums › Apple Final Cut Pro Legacy › RealTime Playback Dissolves & 2nd track
Pete Sake replied 20 years, 8 months ago 4 Members · 13 Replies
Frank Nolan
January 1, 2006 at 10:27 pm>Its just a short piece 3 min final edit and I’ve got loads of room. I’m not going to redigitize it later. So I want to bring it in at a high quality.
In that case use the betacam US 8 bit component uncompressed setting or if you are adding grapics you could use the 10 bit setting. Then make sure your sequence settings match the capture settings and you wont get the render bar.
David Roth weiss
January 1, 2006 at 11:05 pmAs Frank says. 8-bit should really do the job, but 10-bit is better if you have the drive throughput. If your SATA drives are striped together you can do 10-bit, if not you should stick with 8-bit.
DRW
Pete Sake
January 3, 2006 at 2:33 pmThanks for all your help over the New Year. Were now editing FCP.
Next outputing to Betcam 28oo.
Peter
