Activity › Forums › DVD Authoring › re author break point
Posted by John Culleton on December 11, 2010 at 10:07 amis it possible to change the break point on a DVD9 without reauthoring?
i only have the problematic DVD
i have PGC Edit
Daniel Ludwig replied 15 years, 8 months ago 4 Members · 26 Replies -
Eric Pautsch
December 11, 2010 at 12:13 pmSure….just use imageburn to burn the the disc with the new breakpoint
https://forum.imgburn.com/index.php?showtopic=2482
https://forum.imgburn.com/index.php?showtopic=13824
John Culleton
December 11, 2010 at 12:21 pmi need to create a new breakpoint, customer says duplicators wont accept the DVD as is
John Culleton
December 11, 2010 at 12:43 pmthanks Eric, one more Q…
should i use +R or -R media?
i read somewhere that +R is better?
Daniel Ludwig
December 12, 2010 at 9:37 amI wouldn´t give a DVD+DL to replication – use DDP-images as they are the common workflow.
you can give them via DLT, DDP on DVD or as FTP-uplaod.
in case there would be something wrong with the delivered master on DVD as VIDEO_TS, the replication-facility ALLWAYS going to say: “authoring-error, not our fault!”
this could happen especially with DVD+DL in general and the layerbreak-position.
I´ve had a few collegues (here in germany) that has been hit by this! be careful allways! or let the replication-facility (or your customer) sign a paper that they are responcable for probles that could happen using Video-DVDs as premaster for replication, if they recommend you to deliver it as VIDEO-DVD.
I´m sure trai forrester or larry applegate would agree with me.
cheers
danny
John Culleton
December 13, 2010 at 12:14 pmerrrr… slight problem here,
computer says“unable to find any suitable cells that could be used for layer break”
this is using ImgBurn
could be a MAJOR problem?
