Activity › Forums › DVD Authoring › re author break point
John Culleton
December 14, 2010 at 3:27 pmi’ve sent what i’ve done back for them to check, thanks for your time Eric, much appreciated
john
Eric Pautsch
December 14, 2010 at 5:43 pmAny good replicator runs your images through an Eclipse first so you should be OK once it passes that stage. But please get check discs first before the run. Had a client recently who waived that and ran 40K bad discs.
John Culleton
December 14, 2010 at 5:55 pmonly 40K, not TOOOO bad then… OUCH!!!
replicator has thrown this one back already so i think they’ll chk it
thx again…..
Eric Pautsch
December 14, 2010 at 11:59 pmIf you want to contact me offlist, I’ll certainly get this to the replicator for you
poweragemedia yahoo
Eric
Daniel Ludwig
December 15, 2010 at 9:34 pmhe john,
wont be a problem to fix with DVD AfterEdit (MAC-application). it could create a valid layerbreak-position on EVERY Cell/Nav-Pack.I´m a mac-user, so I wont use IMGBurn, but I´ve been told that you can tell it the data-capacity of Layer0, so you´ll get a valid layerbreak-position on DVD+R DL, but it´s a different thing for DDP-images.
my advice: dont give it to replication!
try to find someone nearby that is using DVD AE ME, so he can create the DDP with a valid layerbreakposition for you.
I guess, I can´t do it for you – I´m living in germany.
cheers
danny
Daniel Ludwig
December 15, 2010 at 9:43 pmHey John,
please also look at my notes over here:https://forums.creativecow.net/readpost/55/864428
I haven´t seen the newer posts as I have been written my post. If you use Gearmaster Pro it should be possible to create a valid layerbreak postion as well.
DVD AE automaticly set the new cell/Nav-Pack/layerbreak position to non seamless, that´s a very nice feature!
you don´t need to calculate it, all valid NAV-packs will be shown. to set a new Nav-Pack for the layerbreak is only only one right-click on the selected NAV-Pack.
cheers
danny
