Activity › Forums › Adobe Premiere Pro › Quality Drop After Export
  • Quality Drop After Export
    Posted by Darren Lewis on December 30, 2011 at 4:32 am
    Hello,
    I originally posted this over on the adobe forums, but they were useless, like usual.
    I’ve been running a youtube series for quite a few weeks now and I’ve been using premiere pro CS3 to render out the videos.
    Basically I go through this process:
    1. Record
    2. Import
    3. Export
    Everything works really well up until export. For some reason after I export the video file the quality drops immensely.
    Example:
    Example Image
    I do realize the picture isn’t exactly aligned correctly, but you get the just of it. The quality drops a lot.
    The videos clips are fimled with the following settings:
    Width: 1440
    Height: 838
    Frame Rate: 30
    Bit Rate: 1536
    They are filmed in AVI files.
    My export settings are as so:
    Format: H.264
    Range: Entire Sequence
    Preset: Custom
    TV Standard: NTSC
    Width: 1440
    Height: 838
    Field Order: None(progressive)
    Pixel Aspect Ratio: Square Pixels
    Profile: Main
    Level: 3.2
    Target Bitrate: 6
    Max Bitrate: 10
    Exported as MP4 files
    Thanks in advance,
    Nikc-Nack
    Darren Lewis replied 14 years, 8 months ago 5 Members · 12 Replies
  • 12 Replies
  • Dirk Dejonghe
    December 30, 2011 at 8:09 am
    It looks like you are coming from interlaced footage and exporting to progressive. I don’t know how to handle this in PPro but I had the same problem a few weeks ago. Exporting to interlaced solved the problem. I can convert in Shake or After Effects, but haven’t found the way in PPro.
    http://www.postproduction.be
  • Tero Ahlfors
    December 30, 2011 at 8:31 am
    Why are you using such a weird resolution?
  • Petros Kolyvas
    December 30, 2011 at 3:55 pm
    I would ask this as well.
    Additionally, you mention what the source footage (video) frame size is, and what you’re exporting to, but what are your sequence settings?
    At first glance this looks like a Premiere doing some fast scaling. Either double check the sequence settings (you should, in this case, also be using a custom sequence matching your import/export requirements), or make sure you have you used the “Maximum Quality” checkbox to use high quality scaling on export.
    Let us know how it goes!
    All the best for 2012!
    PK
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • Darren Lewis
    December 30, 2011 at 7:31 pm
    My monitor resolution is 1440×900. And whenever Fraps cuts out the window header and the taskbar it comes to 1440×838.
    My sequence settings are as follows:
    Editing Mode: Desktop
    Timebase: 29.97 FPS
    Frame size: 1440×838
    Fields: No Fields (progressive scan)
    Display Format: 30 fps Drop-Frame Timecode
    Title Safe area: 20% – 20%
    Action Safe Area: 10% – 10%
    Thanks again, I’m a bit of a PP novice as you probably have realized
  • Darren Lewis
    December 30, 2011 at 7:33 pm
    This sounds like it makes a lot of sense.
    I haven’t found a way to export to interlaced. My export options are progressive, upper, or lower.
  • Ann Bens
    December 30, 2011 at 7:48 pm
    [quote]I originally posted this over on the adobe forums, but they were useless, like usual.[quote]
    You are quick to judge, you did not even bother to answer to the response.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Tero Ahlfors
    December 31, 2011 at 11:05 am
    You might try making a standard 720P sequence and fitting the footage in to that. Premiere might freak out at that resolution and some codecs have their own specs on how they work.
  • Darren Lewis
    December 31, 2011 at 3:21 pm
    Thanks for the suggestion, but I still seem to have the same problem.
  • Dirk Dejonghe
    January 1, 2012 at 5:07 pm
    Upper and Lower are interlaced formats. Progressive is progressive. Upper and Lower indicate field priority, depends if you work in PAL or NTSC.
  • Darren Lewis
    January 1, 2012 at 10:34 pm
    I’m working with NTSC, but after trying both neither seemed to fix the problem.
