Activity › Forums › Storage & Archiving › QNAP FCP X Slowdown/Beachball Issue via Thunderbolt 3 & SMB 3 (TVS-1282T3)
  • QNAP FCP X Slowdown/Beachball Issue via Thunderbolt 3 & SMB 3 (TVS-1282T3)
    Posted by Nikos Papadopoulos on February 5, 2018 at 7:56 pm
    Hey everyone from chilly Athens!
    A problem with thunderbolt 3 and FCP X is driving me nuts and was looking towards your wisdom and experiences to help track this issue down. Connected to the NAS via Thunderbolt 3 (40G cable/SMB 3), and trying to create/name/delete a new folder inside an FCPX event, or even attempting playback (normal HD H.264 files from a Canon 5Dmk3) I get beachballs everywhere. This is on a fresh install of High Sierra 10.13.3 and on the Macbook Pro 15″ 2017 with Touchbar. Library and footage is on the NAS. When mounting to the same exact location via a normal 1Gbps Ethernet cable (and smb 3 again) everything runs smooth as butter! I’ve created a short video of the problem. Perhaps with your knowledge you can help in figuring out a solution. I’ve tried almost every trick in the book. Is this the case for you as well via T3? (In the video when I say SD footage I mean HD ☺ )
    Video of the problem: https://www.youtube.com/watch?v=v8I9clZOrMM&feature=youtu.be
    Passion and knowledge put to work
    nick314.com
    Neil Sadwelkar replied 8 years, 3 months ago 9 Members · 46 Replies
  • 46 Replies
  • Bob Zelin
    February 5, 2018 at 11:09 pm
    Just kill me, Nick. I told you to purchase a Promise SanLink3 for 10G connection ($299 US), but you just won’t do it.
    You will sit there for weeks, re format your Mac, jump up and down, and do everything possible so that you don’t have to buy the thunderbolt 3 to 10G adaptor. I HAVE AN IDEA – spend $6000, and get an iMac Pro. It comes for free with a 10G port (from Aquantia) and then you don’t need the adaptor, and then everything will work.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Nikos Papadopoulos
    February 5, 2018 at 11:24 pm
    Hey Bob,
    There are a couple of points to be made. First it is to get this system working – if that means support tickets at QNAP so be it, I have the patience. I could have spend 1000€ less on a non-thunderbolt version and gotten three adapters but I have this perversion that I like to use what I paid for.
    Second is to figure out what’s wrong with the T3 connection. Sanlink 3 won’t cover my needs due to the slow write speeds. Sonnet has issues with High Sierra. And people that are using sonnet are running into the same exact issues, so it seems those adapters won’t fix this – don’t forget FCPX 10.4 can also be at fault.
    As I already have a 40G Thunderbolt 3 connection I’d like to use that since it suits my needs. I have not reformatted so, that’s that. Figuring out what’s wrong can be a learning experience so how about we solve this problem together! Please chime in if you have any ideas on where to look. Cheers!
    I seem to be getting somewhere by tinkering in sysctl.conf with these settings.
    net.inet.tcp.win_scale_factor=8
    net.inet.tcp.autorcvbufmax=33554432
    net.inet.tcp.autosndbufmax=33554432
    net.inet.tcp.delayed_ack=0
    kern.ipc.somaxconn=2048
    net.inet.tcp.rfc1323=1
    net.inet.tcp.win_scale_factor=4
    net.inet.tcp.mssdflt=1448
    net.inet.tcp.v6mssdflt=1412
    net.inet.tcp.msl=15000
    net.inet.tcp.always_keepalive=0
    net.inet.tcp.slowstart_flightsize=20
    net.inet.tcp.local_slowstart_flightsize=9
    net.inet.tcp.blackhole=2
    net.inet.udp.blackhole=1
    net.inet.icmp.icmplim=50
    net.inet.tcp.sendspace=1042560
    net.inet.tcp.recvspace=1042560
    and nsmb.conf with these settings:
    [default]
    signing_required=no
    dir_cache_max_cnt=0
    streams=yes
    notify_off=yes
    port445=no_netbios
    unix extensions = no
    veto files = /._*/.DS_Store/
    It seems to be working for a while, but something is using the QNAP drives in the background and no processes in the QNAP admin verify this – even with all connections disconnected from the NAS. Qsirch disabled and ofcourse no RAID resyncs happening.
    nick314.com
    February 5, 2018 at 11:30 pm
    Also please know that we don’t have an easy way to return products for refunds here in Greece. Store attitudes are far from the US ideal that client comes first, in fact, its the exact opposite. So I can’t just buy one, try it and return it.
    nick314.com
  • Neil Sadwelkar
    February 12, 2018 at 11:58 am
    While I don’t have any direct experience with the TVS-1282T3 unit, I’ve seen some older Qnap T2 units in operation.
    In general, it seems that these Qnap NAS boxes work best over network connections like GigE or 10GigE. I understand that since you’ve spent some extra getting a T3 device, you would like it to work over T3. But the Qnap TVS-1282T3 is not like any other T3 RAID like the one from Areca or G-Tech which are pure RAID boxes. Those work great over T2 or T3.
    The Qnap, implements a T3 connection like a network connection and that’s where it isn’t very good. That has something to do with how the Mac implements network (SMB) over Thunderbolt (2 or 3). You may, with a bit of tinkering and support, eventually make it work over T3 but that is likely to not be as stable as a 10GigE or even a GigE connection.
    So, I’m with Bob as far as simply connecting a 10GigE adapter and getting on with it.
    I too am in a country where buying these boxes and returning them is not an easy option, so I know what that feels like.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Alex Gardiner
    February 12, 2018 at 12:52 pm
    At a guess the kind of bursty/unpredictable performance you see stems from the fact that there is no dedicated hardware handling offload, as would be the case with a real network card.
    I could be very wrong, but that seems likely.
    PS. Tuning something like sysctl is “evil”. This is a good description (originally from an old ZFS tuning discussion). The idea is that the defaults should already be right and if they’re not the problem is likely elsewhere.
    “Tuning is often evil and should rarely be done.
    First, consider that the default values are set by the people who know the most about the effects of the tuning on the software that they supply. If a better value exists, it should be the default. While alternative values might help a given workload, it could quite possibly degrade some other aspects of performance. Occasionally, catastrophically so.
    Over time, tuning recommendations might become stale at best or might lead to performance degradations. Customers are leery of changing a tuning that is in place and the net effect is a worse product than what it could be. Moreover, tuning enabled on a given system might spread to other systems, where it might not be warranted at all.
    Nevertheless, it is understood that customers who carefully observe their own system may understand aspects of their workloads that cannot be anticipated by the defaults. In such cases, the tuning information below may be applied, provided that one works to carefully understand its effects”
    The original link for this is dead (old Solaris stuff), but you get the idea.
    Storage Engineer
    alex@indiestor.com
  • Lutz Leonhardt
    February 13, 2018 at 7:57 am
    hi Nick
    maybe you can contact these people from Rise and Shine Films in swtzerland. They have the same qnap and as it seems no problems with it using thunderbolt 3.
    12157_riseandshinefilms.webloc.zip
    12156_qnaptvs1282t3thunderbolt3nasreviewteil13unboxingundsetupenglischyoutube.webloc.zip
    best regards
    Lutz
    February 13, 2018 at 10:58 am
    Lutz I just came back from Switzerland! Could have gone by!
    Here is the bigger issue. The slowdowns that are cause are also happening on a similar system with the Sonnet 10GbE. The SanLink over T3 has a terrible write speed. This doesn’t give me the confidence to buy a 10G adapter, and being in Greece, I have no option to return it if it doesn’t work. Other people are using T3 successfully, so for now, I’m looking into that direction.
    nick314.com
  • Lutz Leonhardt
    February 13, 2018 at 11:21 am
    I hope you’ll find a solution
  • Joao Ferreira
    February 21, 2018 at 6:23 pm
    I have you try NFS?
    I just install a TVS-1582TU on a client and write speed sucks! TVS-1582TU is connected to a brand new iMac Pro and I try both thunderbolt3 and 10GB connections, write speed is almost the same… I have 8 8TB WD RED Pro static raid 5 with 6 SSD 256GB for cache getting only at maximum 400MB/s write speed and 1300 MB/s read. I run QNAP diagnostic app and under File System Analyser I got 1128 MB/s WRITE and 1535 MB/s Read
    When adding a thunderbolt connection on QNAP you chose the option for FCP X?
    I will continue my tests and i hope that QNAP can fix it …
    Have you fix your problems already ?
    Thanks in advance
    Joao
  • Bob Zelin
    February 21, 2018 at 9:24 pm
    Is this Joao, that used to be with Mean Green Media in Washington DC ?
    With an iMac Pro 10G port that is using the new Aquantia chip, I consistently get 800 – 900 MB/sec write speed with
    the 10G connection to the QNAP (did you enable Jumbo Frames on your iMac Pro, QNAP, and 10G switch ) ?
    With the Promise SanLink3 – as I told Nick, you get 350 MB/sec Write and 1100 MB/sec READ. With Thunderbolt 2 adaptors (on “old” iMacs or Mac Pros) – you get 800 MB/sec Read/Write on the same QNAP. So it’s not the QNAP. The Promise SanLink3 Write speed is SLOWER than the Promise SanLink2 with a thunderbolt 2 connection, for WRITE speeds.
    If you use a $100 ASUS PCIe 10G adaptor with the same Aquantia 10G chip in a Windows 10 PC connected to the QNAP, you get 1100 MB/sec READ AND WRITE on the same system. So exactly what does QNAP have to fix ? Apples issues ? Promise’s issues ?
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
Page 1 of 5
