Activity Forums Adobe After Effects Expressions pushing many objects with expressions
  • pushing many objects with expressions
    Posted by Seth Taylor on February 13, 2009 at 9:14 pm
    I have a bulldozer that needs to push a bunch of different objects to the right side of the screen. I think if I can set up an expression like:
    if _x.object1 > the _x of bulldozer layer do nothing
    but if _x.object 1 <= _x of bulldozer then _x.object = x of bulldozer but I'm not sure how to format this or what else I need to do to get it working properly. Can you help me with this? I have about 100 objects to push 🙂 so it's a bit laborious to keyframe. Thanks, Seth Taylor
    Seth Taylor replied 17 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 13, 2009 at 11:52 pm
    Try this:
    L = thisComp.layer(“bulldozer”);
    x = Math.max(L.transform.position[0] + L.width/2 + width/2, transform.position[0]);
    [x,value[1]]
    Dan
  • Seth Taylor
    February 14, 2009 at 12:01 am
    you probably get this a lot…
    Thanks! It worked! This will now save me a lot of time.
