Activity Forums Adobe After Effects Expressions Projecting 3D to 2Dcomp
  • Projecting 3D to 2Dcomp
    Posted by Jan Sherlink on September 30, 2010 at 6:49 am
    I’ve got 2 circular elements ( A and B ) in 3D-space,
    the circles are moving and the camera is moving too.
    I want to connect the radius of the 2 circles with a “beam”,
    To place the start of the beam on circle A I use;
    p1=thisComp.layer(“A”).transform.position;
    p2=thisComp.layer(“B”).transform.position;
    delta = sub(p1, p2);
    angle=(Math.atan2(delta[1], delta[0]));
    radius=250;
    x=radius*(Math.cos(angle));y=radius*(Math.sin(angle));
    CO1=sub(p1,[x,y]);
    toComp(CO1)
    If i use this data on a 3D-layer it follows the radius correctly but,
    problem is that i can’t seem to project the coordinate to the screen
    to get the beam’s 2D coordinate.
    somebody has a clue ?
    thanks
    cya,
    Jan
    Jan Sherlink replied 15 years, 11 months ago 2 Members · 2 Replies
  • Chris Wright
    October 5, 2010 at 7:46 pm
    if you upload a scratch file, I’d be willing to help find the solution.
    https://technicolorsoftware.hostzi.com/
  • Jan Sherlink
    October 6, 2010 at 10:56 am
    thanks for the offer,
    but I’ve got it solved now.
    Mylenium pointed me to the “Lensflare” script on Dan Ebbert’s site
    (https://www.motionscript.com/masteri…lens-flare.html)
    seems like I was “looking” at my script the wrong way. A new view on it helped a lot.
    fixed it with this:
    L1=thisComp.layer("Bol1");L2=thisComp.layer("Bow1");
    p1=L1.transform.position; p2=L2.transform.position;
    delta = sub(p1, p2); ang=(Math.atan2(delta[1], delta[0]));
    radius=269;L1size=900/2;x=radius*(Math.cos(ang));y=radius*(Math.sin(ang) );
    L1.toComp([L1size-x,L1size-y,0])
    cya,
    Jan
