Activity › Forums › Adobe Premiere Pro › Project setting question
  • Project setting question
    Posted by Don Cobble on May 18, 2013 at 2:57 pm
    I am new switching to PP from Vegas Pro.
    Question about setting up a new project I have an MXO2 mini max. (I only use for rendering H264 files)
    I shoot 1920 x 1080 .mp4 30P (Sony EX1)
    I convert the files to Cineform 1920×1080 .avi 30p (high)
    SO I see these option to use in sequence presets :
    EX1 1920×1080 30p
    Matrox 1920×1080 30p
    What is best setting to use?
    Thank You
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Vegas 10 64bit & Vegas 11 64Bit & Vegas 12 & Adobe Production Premium CS5.5.2 & Avid Media Composer 5.5
    Camera
    Sony EX1 shoot in 1920×1080 30P
    Robert Bracken replied 13 years, 4 months ago 4 Members · 6 Replies
  • Ivan Myles
    May 18, 2013 at 5:15 pm
    Instead of using a preset, you can create a sequence based on the clip settings as described in this post.
  • Don Cobble
    May 18, 2013 at 10:17 pm
    I did as the Post suggested and it set the sequence to from my Cineform AVI 1920×1080 to AVCHD 1920x1080P square Pixel.. Is this a correct setting for an AVI?
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Camera
  • Ivan Myles
    May 18, 2013 at 10:32 pm
    [Don Cobble] “Is this a correct setting for an AVI?”
    Cannot say without more information. These are the key sequence settings; are any different from the source footage?
    – Timebase (aka frame rate)
    – Frame size (horizontal x vertical)
    – Pixel aspect ratio
    – Fields
    – Audio sample rate
    If you are unsure about the source file, right click on it in the Project Panel and select Properties.
  • Ivan Myles
    May 18, 2013 at 10:37 pm
    By the way, have you tried importing the camera files directly without transcoding?
  • Ann Bens
    May 19, 2013 at 1:49 pm
    An avchd preset will do just fine for CF.
    The edititing mode is not that important.
    If I drop a CF avi in the New Item icon I get avc-intra.
    What is important that the framesize, timebase, fields and PAR are correct.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Robert Bracken
    May 28, 2013 at 3:52 pm
    I believe CS6 edits all formats natively, correct?
    Also, I would edit your project first then either export or NEST your sequence into another sized sequence for delivery.
