Activity › Forums › Apple Final Cut Pro Legacy › Problems importing animation quicktimes – file error unknown file
  • Problems importing animation quicktimes – file error unknown file
    Posted by Sean Kapleton on December 19, 2007 at 5:21 pm
    I am working in a DV50 NTSC project with sequence settings @ 720×486 CCIR NTSC (40:27)Lower field dominance with Animation settings for compressor.
    The problem is that when i attempt to import quicktimes with the animation quicktime it gives me the FILE Error Unknown file message.
    I feel like i must be doing something wrong – please someone help me I have a deadline of 4pm today and I cant figure out what i am doing wrong.
    thank you
    Cody Mccormack replied 17 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    December 19, 2007 at 6:05 pm
    Do the animation files play in quicktime?
  • Tom Matthies
    December 19, 2007 at 7:22 pm
    For what it’s worth, If you sequence is DV50 your frame size should be 720×480 and not 720×486. Changing this will possibly size you some problems later in your project. It should save you a lot of render time as well.
    As for the file problems, what program was used to create the animation files. Is it possible that it saves the files in a proprietary format that Quicktime can’t recognize?
    Tom
  • Sean Kapleton
    December 19, 2007 at 8:11 pm
    To answer the questions asked – yes it does play in quicktime and the quicktimes were made in FCP and Avid – but for some reason they will not import into FCP – which is running btw the most up to date version of studio 2.
    I cant figure out what it could be because I feel like i have always been able to import animation qt’s into fcp
    anyone have advice
  • Jeremy Garchow
    December 19, 2007 at 8:15 pm
    If it opens in quicktime, export it from quicktime as a millions+ Animation again.
    Jeremy
  • Sean Kapleton
    December 19, 2007 at 8:18 pm
    That is the setting its on…
  • Jeremy Garchow
    December 19, 2007 at 8:38 pm
    REEXPORT IT as animation, millions+.
  • Cody Mccormack
    August 11, 2009 at 11:48 am
    Jeremy’s right. It worked for me.
    QT file in Animation (millions +) codec generated by Adobe Premiere wouldn’t load into FCP, but would into QT. In QT, Save as didn’t strip sh*t, but Export As fixed it. I thought perhaps it was a frame rate thing because it claimed 24.92 instead of 25, but even when I exported frame rate as Current, size Current, codec the same…it worked!
