Activity › Forums › Apple Final Cut Pro Legacy › Pro Res Plays Over Firewire?
Posted by Kevin Jones on April 22, 2008 at 2:38 pmI dropped a Sony EX-1 1080i project onto a timeline, setup in FCP Easy Setup for DV-NTSC Firewire Basic. I changed the rendering to Pro res and rendered the timeline as usual. Looks great and plays fine over firewire to my Sony DVCAM deck.
It seems counter-intuitive that a Pro res rendered project would play over firewire. Could someone in-the-know explain how this works.
Thanks!Kevin Jones
2.5GHz Quad-core PowerPC G5
Final Cut Studio 2Andy Mees replied 18 years, 5 months ago 6 Members · 22 Replies -
Chris Babbitt
April 22, 2008 at 3:09 pmI don’t think ProRes works with SD. It probably just defaulted to the DV codec for rendering. Try checking your file size. I tried the same thing and then made a self-contained movie. The file size of the movie confirmed that it was rendered in DV and not ProRes.
Andy Mees
April 22, 2008 at 3:13 pmits been a basic feature since FCP 6, Kevin
just as the timeline can play back formats that are not native to the timeline’s settings in real time (aka the all singing all dancing mixed format playback support), so FCP can output a non-native format in realtime using the same principle
Andy Mees
April 22, 2008 at 3:22 pm>I don’t think ProRes works with SD
it does, Chris. in Kevin’s case, as he noted, he used a DV Easy Setup … which sets the External Video to Apple Firewire, then he used a XDCAM sequence w/ ProRes rendering. FCP then did a realtime down conversion to DV over firewire using RT Extreme or whatever they call it ….
take a look at page 8 of the New Features document found under the FCP > Help menu
Jeremy Garchow
April 22, 2008 at 3:22 pmSInce the inception of FCP6, you can play almost anything through firewire. It gets transcoded to dv on the fly.
Jeremy
OOPS. Sorry, should have refreshed before responding.
Chris Babbitt
April 22, 2008 at 3:40 pmHmmm…
I thought Kevin said that he edited the sequence in a XDCAM timeline, then pasted the whole thing into a DV-NTSC timeline before rendering with ProRes. I tried the same thing and the resulting Self-Contained QT movie was no bigger than if I had rendered in DV. Wouldn’t the file have been much larger if it was rendered in ProRes?
ProRes is supposed to work with HDV or XDCAM only. Does that apply to sequences or just clips?
Andy Mees
April 22, 2008 at 4:26 pmYup, I can see where you’re coming from Chris … just our different interpretations of the post I think. Not to worry.
Best
Andy -
Jeremy Garchow
April 22, 2008 at 4:56 pm[Chris Babbitt] “So Andy, does ProRes work in a DV sequence or not?”
ProRes is a codec all it’s own. It is NOT only for HDV based material.
You can put ProRes clips in any timeline, but they will get transcoded to whatever the timeline is with a caveat. With HDV based material (XDCam or whatever), you can set the timeline to render all effects to ProRes and at that point, your media will be ProRes. Confused yet?
Jeremy
Chris Babbitt
April 22, 2008 at 5:17 pmOK, I think I got it, but once again, if you used ProRes for rendering woudn’t the resulting file be much larger than if you rendered with the DV codec? For instance, if I edit a 10 minute long XDCAM sequence and then drop that into a DV-NTSC sequence, render with ProRes and export that to a Self Contained QT file, shouldn’t the file size be much larger than 2 gigs?
Andy Mees
April 22, 2008 at 5:19 pmexactly … clear as mud 🙂
ProRes is a quality intermediate codec that can be used to encode both HD and SD media, though most commonly and famously its being used for compressing HD sources to data files that retain the image quality yet at manageable file sizes … can it be used in a DV sequence? of course, but as Jeremy points out, when rendered it would be rendered to DV.
If you’re looking for some means to leverage the new codec with a DV workflow ythen ou might instead choose a ProRes SD Easy Setup, editing your DV native files in a ProRes timeline. Similarly you might instead take advantage of the Open Format Timeline to work with your DV clips in a DV50 or IMX50 timeline, both better codecs native vanilla DV.
Hope it helps
Andy
