Activity Forums Apple Final Cut Pro Legacy Pro Res Plays Over Firewire?
  • Chris Babbitt
    April 22, 2008 at 5:59 pm
    No, sorry Andy, that doesn’t help. I’m really confused now. Are you saying that if I’m working in a DV sequence with rendering set to ProRes, the final rendered file will be DV, not ProRes?
    ..and why, when you select ProRes as the rendering codec in Sequence settings, does it say HDV and XDCAM only?
  • Chris Babbitt
    April 22, 2008 at 6:14 pm
    Sorry I’m such a pest.
  • Kevin Jones
    April 22, 2008 at 6:15 pm
    Just tried it with an XDCAM clip in an XDCAM timeline rendering to Pro Res. Yes it will play over a firewire if you change the Easy Setup to Firewire Basic, but the image is so degraded as to be unusable.
    Kevin Jones
    2.5GHz Quad-core PowerPC G5
    Final Cut Studio 2
  • Jeremy Garchow
    April 22, 2008 at 7:48 pm
    [Chris Babbitt] “..and why, when you select ProRes as the rendering codec in Sequence settings, does it say HDV and XDCAM only?”
    Because that’s the only codec you need this type of functionality for. ProRes becomes an intermediate codec so you don’t have to deal with HDV rendering. All other i-frame codecs don’t require this as they work just like ProRes in terms of their i-framiness.
    Jeremy
  • Jeremy Garchow
    April 22, 2008 at 7:49 pm
    [Kevin Jones] “Yes it will play over a firewire if you change the Easy Setup to Firewire Basic, but the image is so degraded as to be unusable.”
    I would assume it’s for preview purposes only, like if you don’t have a capture card to monitor with but still needed to get an image out to a monitor via firewire/dv deck.
    Jeremy
  • Chris Babbitt
    April 22, 2008 at 9:00 pm
    So, if I have a graphics-heavy DV project, it won’t give me a better result to render with ProRes over using the DV codec?
  • Jeremy Garchow
    April 22, 2008 at 9:40 pm
    Chris, when using a dv timeline, you cannot render to the ProRes codec. You must edit in a ProRes timeline and yes it will help your graphics.
    Jeremy
  • Chris Babbitt
    April 22, 2008 at 10:00 pm
    OK!
    That explains it. Thanks Jeremy.
  • Jeremy Garchow
    April 23, 2008 at 4:01 am
    You are very welcome.
  • Ben Scott
    April 23, 2008 at 9:47 pm
    thought to say prores is made mainly for HD and firewire output you are seeing is SD downconvertion in FCP6
    maybe this is useful to help with some of this stuff
    https://cowcast.creativecow.net/podcast/final-cut-pro-open-format–213
    wasnt aware prores downconverted in same way a HDV must be a recent upgrade cause I remember it only being HDV when fcp6 got first released
Page 2 of 3
