Activity › Forums › Apple Final Cut Pro › Pro Apps Codec update = loosing 2nd monitor
Chad Smith replied 12 years, 1 month ago 5 Members · 36 Replies
Jeremy Garchow
July 17, 2014 at 1:26 pmUpon restart, hold option. Do it right after the chime, before grey screen.
From there, you should be able to choose recovery disk.
Once booted to recovery, the first thing I would do is use disk utility and repair permissions.
Then reboot to normal.
If you are still having problems, reboot to recovery and reinstall. Make sure you have all of your data backed up before reinstall.
If none of that works, you have to download Mavs from AppStore.
Chad Smith
July 17, 2014 at 6:37 pmTried re installing the os from the recovery disk and same issue. Installed Mavs on an old system disk that had Snow Leopard on it. Same issue. Tried to update the cuda driver from 4.2.10 from within the pref pane and the update fails.
Need to get running for a color job that starts on Monday. Perhaps I need to build up a new SSD from the ground up?!
Jeremy Garchow
July 17, 2014 at 6:51 pm[Chad Smith] “Tried re installing the os from the recovery disk and same issue. Installed Mavs on an old system disk that had Snow Leopard on it. Same issue.”
If you have this issue in two OSes, that port may be dead.
Chad Smith
July 17, 2014 at 7:04 pmHowever when I boot the same machine under 10.8.5 BOTH monitors are working with the GTX 680 card.
Chad Smith
July 17, 2014 at 9:59 pmAfter re formatting a drive, installing 10.9.4, downloading the cuda web driver, repairing permissions, restarting a number of times, I still have the same issue of only one monitor operational under 10.9.4. going into the preferences and selecting the cuda updater it says that there is a newer version available, once it try to install the new driver it fails at 20% each time. No difference with web driver or OSX driver.
So for now once again all FCPX work will have to be done on one monitor. Just went through this same thing a few months ago. All of this does not feel very pro to me. Perhaps I just need to purchase the $6000 dongle.
Hopefully nVidia will have the latest driver available for web download sometime soon.
Chad Smith
July 29, 2014 at 3:38 pmUpdate: Following the instructions about halfway down this page from “therandyzone”
https://discussions.apple.com/thread/6430600deleting the kext files downloading the other ones in the link and installing them with Kext Utility has worked for me. I now have my second monitor back on my GTX680 running under 10.9.4. Very happy 🙂
