Activity › Forums › Adobe Premiere Pro › Premiere Pro CS6 is not playing back
Miloš Milićević replied 10 years, 1 month ago 42 Members · 60 Replies
Vincent Robinson
March 8, 2013 at 2:46 amI’ve run into this in a Lab situation — 4 of 10 machines hit with it. All iMacs (iMac 7,1; 2.4ghz, 4gbRAM; CS6). Haven’t tried the intriguing fixes in this thread yet, but found a sequence that worked with at least one of the machines (will be trying it on the others next week): Projects are normally edited in a “standard” account, where the error was cropping up. Tried opening and playing clips under an “administrator” account and they played properly. Then, trying them under the standard account, they suddenly worked.
What I don’t yet know is whether whatever was rectified by the operating in the enhanced permissions environment only fixes that particular project (in this case, on an external FW drive), or whether the issue is fixed for the machine as a whole. I’ll report back to this thread what I find.
Hope this helps others, too.
Pablo Biglang-awa
March 26, 2013 at 4:09 amI’m on Macbook Pro (mid-2012). I also had the same non-playback issue. I thought it was because of my recent OS X uodate to 10.8.3 or a CUDA driver issue but I found out that the culprit was in my Premiere CS6 Audio Hardware Preferences setting. I recently switched my >Preferences>Audio Hardware>Default Device> to Motorola S305 bluetooth headset. I just switched back to System Default Input/Output and it now works.
Samu San
April 4, 2013 at 10:44 pmLast days I had the same issue witth Premiere CS6, and today I solved it: I was using CS5.5 workspace, I changed it to cs6 workspace and the previews returns! Maybe is also becouse I use 2 monitors, try to preview the workspace in each monitor
Robert Libel
April 22, 2013 at 8:15 pmHi,
I’ve this problem also since CS3 i think.
Try to remove all disabled (grey colored) audio element from timeline. If that’s not work delete the sequence elements one by one until it begans to play the sequence again.sorry for late answer
i get this problem just these days.. -
Bjorn erik Lillehagen
April 25, 2013 at 7:23 amI had this problem, as many others.
I have tried :
Remove the Aggregate Devices plist file.
Loged in as the root user. Once you are logged in as root, relaunch your Adobe software and repeat the process that generated the error. After you have verified that the software functions correctly, you can return to your regular user account.
Reinstalled my OS
Reinstalled PP 6
No luckThen I made a new user account which I use when working with PP and everything works fine !
Bjorn Erik
Tony Poon
April 30, 2013 at 7:10 pmHello I’ve had the same problem, and I simply changed my workspace from “editing” to “editing cs5.5” and that seemed to do the trick!
Isaac Nankavill
May 11, 2013 at 7:45 amI’ve been having this problem for months now (rMBP 15″) and have gone through numerous re-installs of CS6 (Creative Cloud). After reading your comment about Hear, I decided to uninstall and it has fixed the issue for me after re-installing Premiere. Thanks!
Mike Kazin
June 18, 2013 at 6:57 pmAfter a few days of battling this same issue, I realized it would only happen after I added music to my timeline. I then remembered that I had changed my settings for the audio in the PREFS. So my fix was as follows…
Preferences
Audio Hardware
Change from BUILT-IN INPUT and OUTPUT to SYSTEM DEFAULT IN/OUTEver since then I’ve never had an issue. Hope this helps someone
Daniel Hill
July 11, 2013 at 3:58 pmRe: However when i press spacebar or click the play button, it doesn’t move – Usually this has to do with the Audio Hardware selection. Go to Edit -> Preferences -> Audio Hardware and try switching it to Premiere Pro Sound then it should play. Worked for me.
Skyler Meek
July 22, 2013 at 9:10 pmHad a project magically switch over to the playback issue this morning. Not sure if i’m just stupid it what, but after looking at every solution i’ve read in this thread so far with no success – I noticed an option within the playback settings (right click on your source and click on playback settings) labeled “Desktop Video Display During Playback” mine was unchecked. After I checked it, playback was back to working perfectly with no issues. Now the option’s grayed out.
Maybe worth looking at if there’s someone out there who hasn’t tried that yet.
Mac OS X 10.7.5
CS5.5
