Activity › Forums › Adobe Premiere Pro › Premiere Pro CS6 is not playing back
Miloš Milićević replied 10 years, 2 months ago 42 Members · 60 Replies
Tom Daigon
December 16, 2012 at 1:54 amPlease report it here 😀
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=DxPrG3WUyz8
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
Jack Slattery
December 18, 2012 at 4:58 amI’ve been away working on other editing software, I just left premiere pro for a little while, then came back and then it worked. I assume it’s updates.
Andrew Saliga
January 17, 2013 at 10:58 pmHas this issue resolved for everyone else?
We are having this same issue on three different machines. We’re running PP 6.0.2, no GPU acceleration enabled cards, and working with 5K RED raw.
I’ve tried deleting various pref files, running disk permission repairs, standard tests for corrupted clips/projects, etc.. They issue will appear to be fixed, then randomly pop back up with no apparent reason.
And to clarify, the problem I’m having is that when I initiated playback the sequence does not play, but the button indicator does change from the triangle to square. PP does not crash or lock up, it just never begins playback.
Andrew Saliga
I/O Specialist/Assistant Editor
Steelehouse Productions
http://www.steelehouse.com -
Ondrej Homola
January 27, 2013 at 3:13 pmGuys I have exactly same issue!! On Retina 15, 16GB RAM with Creative Cloud. Suddenly it stopped working! Many people seem to have the same issue, here is some discussion: https://forums.adobe.com/message/5025653#5025653
and no answer .. wtf
Jon Simms
January 27, 2013 at 5:44 pmThe only way I got it to resolve was a complete reinstall of CS6. I tried pretty much everything I could have without a reinstall, including close to 6 hours on the phone with Adobe tech support. In the end the reinstall was the only thing that worked.
I did pin point that Hear (a systemwide graphic equalizer for Mac OS X) was causing some conflict, although I now don’t recall exactly what. But I have not reinstalled Hear. I mention this just in case anyone else with this issue has Hear installed. It would be interesting to know.
Tristan Summers
January 28, 2013 at 2:12 pmWhen I deleted the audio track, then hit UNDO, Premiere began playing again.
Perhaps this could offer a clue as to what was causing it.
Are those with the problem running 64bit systems on relatively recent graphics cards?
Tris -
Rohan Cornwall
January 31, 2013 at 5:53 pmI have to restart my computer thats the only way I get PP CS6 to start playback again….
Andrew Baker
February 6, 2013 at 5:18 pmOne of the answers: I had the “no audio playback”
Video play back worked but no audio was coming out of the Macpro, I could change the volume and hear the sound coming out of the computer but JUST not from Adobe Premiere CS6.
ANSWER: GO TO PREMIERE PRO, PREFERENCES, PLAYBACK, and in there I changed audio device to: Adobe DV.
This playback section is where you would change the options to your specific mac, we use a Matrox box which options showed matrox player in AUDIO DEVICE. Once that was changed the audio WORKED again,
Looks like the box was hooked to some speakers which used to work with the old option but with out it….dead sound/no sound coming from the program. I now wear speakers and it works both from the computer speakers and my headphones.
John Baumchen
February 11, 2013 at 4:17 pmI’m having the same problem on an editing workstation with CS6. The audio will stop playing after 4-5 seconds, video plays fine. The timeline has been rendered. If I hit the stop/pause key, (spacebar), and hit it again, it will play for another 4-5 seconds before the audio drops out. Sometimes only one audio track will stop playing.
Audio is 48K, 16 bit.
Video is 720P, two audio tracks, three video tracks. System is win 7-64 with an intel I7 extreme CPU, 12 GB RAM (9GB dedicated to Premiere, performance mode)
Any suggestions?
Akbar Ah
February 20, 2013 at 4:10 amNot sure if this will help anyone else but I managed to fix my problem. I use an external soundcard with my iMac.
I went to ‘Audio Hardware’ and ‘Audio Hardware Mapping’, switched it to Built-in, then hit okay.
I hit spacebar on my project, it worked, then I went back and set it back to my external and it seemed to work!
Hope the helps somebody as I was getting extremely frustrated with this one!
