Activity › Forums › Adobe Premiere Pro › Premiere Pro CS6 is not playing back
Miloš Milićević replied 10 years, 1 month ago 42 Members · 60 Replies
Ken Hansen
April 11, 2015 at 2:23 amI had the same issue. Previously created projects that played back fine before stopped playing audio. For me the solution was to Premier Pro preferences, select audio hardware, and under default device select system default, input/output. Mine had somehow changed to “built-in line direct” which did not work.
Ken Hansen
Hansen Photo Inc.
ken@hansenphoto.com -
Robin Markowitz
April 12, 2015 at 5:06 amThe problem for me is video, not audio. Unless I disable the Mercury Playback Engine for my supported card which worked, my editing screens are black. I can hear audio.
This happens with files and projects that previously worked fine.
CS6 Production Premium. Windows 8.1. NVIDIA GEOFORCE 650M. It’s on my list *on* my machine of supported cards. I started out with Win7.
If I can’t find a fix, I will chalk it up to a loss and get Sony Vegas. Photoshop and After Effects seem unaffected so far. But the Mercury Playback Engine is quite important to the video editor.
This is not an Apple issue. But it is bizarre that it worked before.
Any help appreciated. I do not want to give up on the application altogether.
Best,
Robin -
Ma Kris
November 16, 2015 at 5:01 amhello! I had the same issue with my premiere pro…
I tried so many different things and nothing worked but when i went into the audio preference option and into the audio hardware, and changed the default speaker output from output to speaker(realtek high def audio) then the playback magically started working! hope this works for you! -
Ma Kris
November 16, 2015 at 5:08 amhello again! so i just realized that the in my case, i have to have the headphones plugged into the desktop at all times if i want the playback to work… so hopefully it’ll work for you when you have earphones plugged in with the audio setting set to speaker not output.
Peter Meister
December 31, 2015 at 11:06 pmHi.
Using a PC with multiple drives and an NVIDIA 760.
Just a few notes as I had the problem that my space bar and play button were not letting preview video play in Adobe Premier Pro CC. The option to use the Mercury Playback Engine GPU Acceleration was also grayed (greyed) out. I guess I fixed it. I had been swapping between speakers and my USB headset (yanking the headphones out willy nilly) while working on the soundtrack for my video in Audition, and my computer, or adobe software, did not like that. Somewhere along the line things stopped playing on Audition so I fiddled with the audio hardware. Well, when I got to Premiere, Premiere would have none of that. I couldn’t get the space bar or play button to work, turns out that redoing the settings in Audition helped things out. (Oh… so that was what that mysterious pop up warning was when I changed my hardware settings in Audition – HA)Along my merry troubleshooting way, which included restarting Premiere and the computer, I got a message that Premiere could not find a CUDA compliant GPU. Strange. I know the NVIDIA 760 is compliant. Here was Premiere telling me it wasn’t going to use my once-pricey video card. I was certainly not going to use software acceleration with my pretty old CPU (i3).
If Premiere is not recognizing your graphics card, which you know is CUDA (it’s most likely a PCI express card), your Premiere may be attempting to use some lame motherboard based graphics chip, which generally stinks. IF you have access to your bios, restart the computer and go into BIOS setup. Under peripherals in your BIOS menu, instruct your computer to launch graphics from your video card and not internal graphics. The setting is called ‘PEG’
Select “GFX0” or “PEG” to switch to a peripheral component interconnect express card, “PCI” to switch to a PCI card, “AGP” to switch to an accelerated graphics port card or “GPP” to use multiple graphics adapters. “IGFX” is a setting that will use your motherboard’s OEM graphics, which generally, as I said before “stink”. There is also sometimes an option called “Auto” which lets the bios decide, but I’ve been suspicious that it ignores my card.
Anyway,if your bios startup setting is on “auto” you may be trying to run Premiere off your mother board and not your super expensive graphics card.
I set my bios to PEG, restarted the computer, made sure I was using the same audio hardware settings on both Audition and Premiere, and so far the space bar not working problem seems to have been fixed. I was now granted the well earned right to use the fabled Mercury Playback Engine GPU Acceleration. I felt like I just strolled into the swankest club in town.
Now with all this knowledge there is ONE caveat: If you set your bios to “PEG” or whatever setting uses your graphics card first, and for some reason a buggy update has wrecked your graphics drivers, you may wake up one morning before a major project is due, and find your screens won’t work. Restarting does nothing.
Calmly open up your computer (CALMLY) and remove the card and start up the computer again. It will go to the motherboard graphics drivers even if the bios is set to PEG. Then another chapter will begin in your journey to say “WHY ME, GOD?” and throw the computer out the window as you attempt to fix your video card drivers. You will eventually fix them (after the client storms out and heads back to Tulsa) and then you can set your bios to PEG again and bask in the glory of a computer that will function until… the next software update. GOOD LUCK!
Ulianka Maksymiuik
January 14, 2016 at 9:03 pmI know it is an old post but maybe someone else will need it.
I had the same symptoms and video didn’t play whatever I changed.
But then I’ve changed sound source (sound hardware)to main speakers and back to headfones, which I always use. It started work straight away! Hope that helps. -
Eke Godfrey
January 19, 2016 at 9:31 pmI just duplicated the sequence, copied items from sequence one and pasted it on sequence 2. And eeverything started working fine.
Ryan Coquilla
April 27, 2016 at 9:51 pm@tomknight this totally worked for me too. I think it’s because I switch listening to music through my headphones from my phone to my PC. Sometimes audio doesn’t play when watching something on the web (youtube or whatever) so I have to refresh the browser. Whatever is affecting that, is probably affecting premier in the same way.
Lisa Bradley
April 28, 2016 at 8:02 pmDid you see if your OS was compatible? That might be the case.
Lisa Bradley
Editor/Videographer -
Miloš Milićević
July 19, 2016 at 10:20 amI had the same problem on Premiere CC 2015/Windows. Solution was Edit/Preferences/Media and choose Indeterminate Media Timebase same as sequence fps.
