Activity Forums Adobe Premiere Pro Premiere Pro CS4 – AME – exporting quality issues
  • Premiere Pro CS4 – AME – exporting quality issues
    Posted by Nathan Gross on March 26, 2009 at 2:18 pm
    I have yet to be impressed with AME CS4 for OSX. I am nowhere near a professional but not a newbie either. I am working with some HD (768×1280 – Vertical) animations created in AE (Exported Lossless – 500MB). I put them together in Premiere Pro CS4 – Export -> Media – opens up AME. I have tried many settings, codecs, etc. and it seems that no matter what I do I get a 2.6MB file that looks terrible.
    What I am trying to get is a high quality QuickTime, H.264 file. I have tried maxing every setting. Still the same terrible 2.6MB file.
    I’m sure I’m leaving a lot of info out.
    Help would be very much appreciated.
    N
    Nathan Gross replied 17 years, 5 months ago 7 Members · 28 Replies
  • 28 Replies
  • Vince Becquiot
    March 27, 2009 at 4:24 am
    Any reason why you are using this particular resolution ?
    What is the actual format, what 3D application were they exported from, and finally what are your project settings ?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Rex Monga
    March 27, 2009 at 5:38 am
    hey buddy u want a quick time output or a mpg2
    try once mpg2
    go to ame choose mpeg2
    vedio
    quality 5
    size as per u
    progressive field
    profile main
    level main
    VBR2
    max bit rate upto full
    target bit rate adjust according the file size in mb it will show uy in bottum and the min bit rate same as target
    and render it
    do let me know if it works
    regards
    rex monga
  • Nathan Gross
    March 27, 2009 at 1:49 pm
    We are creating these videos for use at multiple trade show exhibits. They will be displayed on rotated plasma screens. I realize the resolution is not a standard HD resolution but those were the specs given to us by the display company.
    These videos are showcasing medical devices. Each medical device has a 25-30 second animation that was created in AE. We basically set up a sort of template animation and swap out text and images for each device. We export each device animation from AE with the default settings (Lossless QuickTime). This creates a pretty large file (500MB – 1 GB). We keep each device animation (we call these modules) as separate files until we combine certain ones for a specific trade show. Each show has a different line up of devices.
    Our workflow in the past (and seems to work ok) has been just to use QuickTime Pro to combine the video modules (usually between 5-10 modules) and export to a .mov with the following settings:
    Compression: H.264
    Quality: Best
    Frame Reordering: yes
    Encoding: multi-pass
    Dimensions: 768×1280 (Current)
    This exports a hi-quality video with a small file size. Great.
    I thought we could speed up the process by using Premiere Pro. Unfortunatley I have yet to figure out how to export a .mov anywhere near the quality of exporting from QuickTime Pro.
    Here are screen shots of the settings:
    https://downloads.rocketsciencedesign.net/AP_1.png
    https://downloads.rocketsciencedesign.net/AP_2.png
    https://downloads.rocketsciencedesign.net/AP_3.png
    Is there a way to just export an uncompressed video to compress it in another application?
  • Nathan Gross
    March 27, 2009 at 1:51 pm
    I would prefer a QuickTime file but I will try your mpeg2 settings. Thanks!
  • Nathan Gross
    March 27, 2009 at 2:03 pm
    I cannot seem to get mpeg2 basic settings to do 768×1280. Am I missing something?
  • Vince Becquiot
    March 27, 2009 at 3:35 pm
    Nathan, where is you export going to be shown, how will it be played back ?
    Vince Becquiot
    Kaptis Studios
  • Nathan Gross
    March 27, 2009 at 3:49 pm
    The videos will be ran off of a laptop running quicktime fed to a plasma screen—I believe 768×1280 native resolution (when rotated)
  • Vince Becquiot
    March 27, 2009 at 5:07 pm
    Nathan,
    You really need to keep that 16:9 ratio or you will be running a stretched video (or see bars). 1280×720 could be native to the plasma, but it could be higher if it’s a newer model.
    Try to match to Plasma’s native resolution and make sure the laptop supports that resolution as well.
    As far as output formats go, H.264 will probably be the best format you can pick for playback. I usually pick 10 Mb/s VBR for HD. For that, you will need a fairly new machine for smooth playback.
    Anyway to post a screenshot ?
    Vince Becquiot
    Kaptis Studios
  • David Dobson
    March 29, 2009 at 6:46 pm
    AME doesn’t like quicktime. Especially H.264 as quicktime. All the changes to the template are ignored – or at least this has been my experience. However – you can export just fine as h.264. This creates .mp4 fils which quicktime can play back (if the bandwidthe is low enough or the computer is fast enough – but that’s normal with quicktime too.)
    It really does seem that Adobe is trying to kill quicktime. I’ve given up on it almost entirely now and use h.264 for almost everything – which is fine because it is a mpeg4 and creates some very nice images at quite reasonable data rates.
  • Eddie Lotter
    March 29, 2009 at 8:52 pm
    [David Dobson] “AME doesn’t like quicktime.”
    Who does? 😛
    Actually, the changes are not ignored, they are not saved in the queue. You should revisit the settings in the AME interface and set them the way you want and then start the queue.
    Alternatively you can apply the 4.0.2 update to AME.
    Cheers
    Eddie
Page 1 of 3
