Activity › Forums › Adobe Premiere Pro › Premiere Pro and broadcast levels
  • Premiere Pro and broadcast levels
    Posted by Craig Ricker on February 18, 2013 at 11:52 pm
    Hey guys, I have been doing a lot of reading in regards to getting color and luminance levels ready for broadcast. I live in Australia and we abide by Rec.709 for HD and Rec.601 for SD. Both of these use 16-235 for their luma range (unsure of the chroma range) I suspect 100% for HD and 75% for DV Pal.
    But I still find myself confused on a couple of issues.
    The main one is in regards to the whole 0-255 color space. We shoot using a JVY GY-HM750E in 1080p, and on my waveform scope I see anywhere from 0.3v to 1.1v. It never ever goes below or above those values. Is this a 0-255 color space or is the camera shooting in 16-235?
    Now as far as I’ve read this voltage scale means nothing as that refers to analog. So how do I understand the scale in terms of digital?
    Does the 0.3v mark refer to 0 in a 0-255 color space? Or does it refer to 16 in a 16-235 color space?
    Same question in regards to white. Is the 1.1v referring to 255 and thus I wish to pull my whites down to 1.0v as they then are adjusted correctly to be at maximum 235.
    I am struggling with the connection between digital measurements (i.e 0-255) and a analogue waveform.
    That moves us onto chrominance.
    To ensure I am meeting the broadcast legal standard for chrominance I can use the vectorscope. I understand what the vector scope is showing, but I do not know if my levels are supposed to fall under 75% or 100%? When I put up DV Pal bars the vectorscope shows maximum chrominance of 75% where as when I put up HD 720p Bars they show maximum chrominance of 100%. Is that a hint as to what is legal?
    RGB Parade…
    Is this showing the luminance values of each individual color channel? I assume this is more for color correction than actually bringing levels into safe limits, as every channel appears to be clipped on all colors. And thus what is safe limits?
    Waveform with chrominace box ticked on.
    Displaying the chrominance on the waveform. It is much higher in areas than what the luminance is alone. For example, I place 720p bars on a 720p sequence and view it on the waveform. I see chrominace levels ranging from what would be 0v to 1.3v. The luminance of these bars rests from 0.3v to 1v.
    Where as when I put DV Pal bars down. I see chrominace levels from 0.1v to 1v. So maybe that is the chrominance safe limits for dv pal broadcasting?
    Here is another test I could not get to work. I create a 0,0,0 black, a 255,255,255 white and a 16,16,16 in photoshop. No matter what color profile I gave the document when I displayed this graphic on my 720p timeline it displayed 255,255,255 as 1.0v 0,0,0 as 0.3v and 16,16,16 as like 0.35v
    So I could not get any graphics to fall into what I suspect is “illegal white” of 1.1v?????
    So if there is someone out there, that understands what the heck is going on with color space on a computer and how that interprets into color space for TV, and how to use the scopes to know where broadcast safe limits are, PLEASE enlighten me!
    I’m heading to NAB later this year and i’ll certainly be asking around on this one!
    Mac Pro 2 x 2.4Ghz, 16GB RAM, GTX 660
    Angelo Lorenzo replied 13 years, 7 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    February 19, 2013 at 2:18 am
    *Sighhhhhhhh
    Alright, lets get this started.
    From https://camerahandbuch.wordpress.com/2012/08/03/premiere-rgb709-problem/ (edited for clarity)
    “YUV and RGB do not traditionally have the same black and white levels. In 8-bit YUV, black is represented as 16 but in 8-bit RGB black is 0, and 8-bit YUV white is 235 but 8-bit RGB white is 255. Any values under 16 in YUV are considered Super Black and any values over 235 are considered Super White.
    Many applications (like Final Cut Pro, Premiere Pro, After Effects) will convert YUV to RGB in such a way that expands and maps the black/white levels of YUV to the black/white levels of RGB, and likewise they will convert RGB to YUV in such a way that contracts and maps the black/white levels of RGB to the black/white levels of YUV. This is considered converting YUV to Full Range RGB (or Computer Range RGB) because the 16-235 values of YUV are expanded and mapped to the Full Range 0-255 of RGB.
    While technically Super White and Super Black are illegal YUV values, some users do like to preserve them in their workflows and so there are some applications like Sony Vegas and Avid Media Composer that are aware of the color levels differences of YUV and RGB data. These applications allow workflows where YUV can be converted to/from RGB that provides more of a one-to-one mapping of the color levels where 16-235 YUV is converted to 16-235 RGB. This is considered converting YUV to SMPTE Range RGB (or Video Range RGB) because the 16-235 values of YUV are mapped to 16-235 RGB.”
    This would map 0 IRE or, in the case of PAL, 0.3v to an RGB value of 0, and 100 IRE/1.0v to a value of 255. https://forums.adobe.com/thread/1107336
    Use your program scopes and, if you have access to external scopes, please check program material. Do not use RGB values in Premiere to make any critical evaluations when it comes to broadcast levels as RGB levels will be compressed when output to a YUV video format.
    If you want to preserve super whites and super blacks, you need to take care to use effects that process YUV directly (they will have a YUV icon) and export to a YUV supporting video format. If some care isn’t taking then you’ll just clamp to YUV legal values.
    [Craig Ricker] “That moves us onto chrominance.
    To ensure I am meeting the broadcast legal standard for chrominance I can use the vectorscope. I understand what the vector scope is showing, but I do not know if my levels are supposed to fall under 75% or 100%? When I put up DV Pal bars the vectorscope shows maximum chrominance of 75% where as when I put up HD 720p Bars they show maximum chrominance of 100%. Is that a hint as to what is legal?”
    https://blog.ieba.com/wp-content/uploads/2010/06/ReadWaveformVector.pdf
    https://forums.creativecow.net/thread/3/866589
    75% is your setting for both PAL and NTSC; the first link will teach you how to read a vectorscope.
    [Craig Ricker] “RGB Parade…
    Is this showing the luminance values of each individual color channel? I assume this is more for color correction than actually bringing levels into safe limits, as every channel appears to be clipped on all colors. And thus what is safe limits?”
    RGB and YCbCr parades are for color correcting only, you’ll notice their scales are an arbitrary 0-100. I would suggest trusting the YC waveform with the chroma overlay in addition to the vectorscope.
    As for some of the specifics of legality, I’m not familiar enough with PAL to say how far the chroma can fall outside of max luma (NTSC allows for an additional 20%) or how PAL color bars should be laid to tape.
    [Craig Ricker] “Here is another test I could not get to work. I create a 0,0,0 black, a 255,255,255 white and a 16,16,16 in photoshop. No matter what color profile I gave the document when I displayed this graphic on my 720p timeline it displayed 255,255,255 as 1.0v 0,0,0 as 0.3v and 16,16,16 as like 0.35v
    So I could not get any graphics to fall into what I suspect is “illegal white” of 1.1v?????”
    See the first set of paragraphs. Unless you use some wayward workarounds, because Premiere uses full range RGB, it’s not really possible to get superwhites from graphics. If you’re using AE to create overlays then you may want to be critical of your RGB levels if, say, you’re bringing it to Avid in an RGB based video file or image sequence.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
