Activity Forums Adobe Premiere Pro Premiere Pro 2017.0.1 Laggy “Play” playback – GTX 1080, SSD Raid, Xeon E5-2630 2.20 GHz (2 processors)
  • Premiere Pro 2017.0.1 Laggy “Play” playback – GTX 1080, SSD Raid, Xeon E5-2630 2.20 GHz (2 processors)
    Posted by Sander Somma on February 27, 2017 at 2:14 pm
    Greetings! No response at offical adobe forums.
    System info:
    GTX 1080
    SSD 0 Raid (hardware)
    128 GB Ram
    Problem:
    Adobe Premiere is lagging, freezing when using “Play” button. Fine when scrolling timeline.
    File type: MXF, 2k.
    Also strangely, when this lagg occurs, task manager reports 100% CPU usage. Also after the start up “play” lag, it countinues fine, at 2% CPU usage.
    I could not find anything on this matter, a few older threads around the web with no answers. Can anyone help me out please?
    Thank you!
    Chris Borjis replied 9 years, 6 months ago 7 Members · 16 Replies
  • 16 Replies
  • Gary Huff
    February 27, 2017 at 2:45 pm
    [Sander Somma] “Adobe Premiere is lagging, freezing when using “Play” button. Fine when scrolling timeline. File type: MXF, 2k.”
    What codec are you recording to?
  • Sander Somma
    February 27, 2017 at 3:02 pm
    Hey! Recording? Im not recording to any codec yet. Playing back the material when editing is laggy and freezes. CPU jumps to 100% for a second, have not had any similiar trouble. I read somewhere it might be about raid doing double checking or something, but does not make sense because its freezing and laggy because CPU jumps to 100% for a moment. Seems like an software issue, but if that would be the case then this wouldnt be such unusal problem.
  • Joy Kawk
    February 27, 2017 at 3:10 pm
    what’s the codec of your video and what’s your sequence setting ? I’m not sure but laggy playback happened when they were different as far as my expericne concered….
  • Sander Somma
    February 27, 2017 at 3:17 pm
    Hey!
    Thanks for replying guys!
    I tried “New sequence from clip” and different sequence settings, did not change anything.
    Sequence settings:
    1920×1080
    Square pixel
    25fps
    Editing mode: arri cinema
    Compsite in linear color
    Material properties:
    File Size: 21,23 GB
    Image Size: 2048 x 1080
    Frame Rate: 25,00
    Source Audio Format: 48000 Hz – 24 bit – 4 channels
    Project Audio Format: 48000 Hz – 32 bit floating point – 4 channels
    Total Duration: 00:14:20:16
    Pixel Aspect Ratio: 1,0
    MXF File details:
    Wrapper type: MXF OP1a (type: SingleItem SinglePackage MultiTrack Stream Internal)
    File generated by: CANON, EOS C300 Mark II (1.00)
    AVC Intra 444
  • Joy Kawk
    February 27, 2017 at 3:22 pm
    Ah, you are working on MXF files too?(Me too) Are you editing MXF in CC or CS vertion? ‘Cos I found that the playback of MXF is more smooth in CS6 than in CC. (just my onw opinion….)
  • Sander Somma
    February 27, 2017 at 3:25 pm
    Hey! Yes,
    Premiere Pro CC 2017.0.1
  • Sander Somma
    February 27, 2017 at 4:26 pm
    Hey!
    These are straight copied to SSD raid, original clips.
  • Chris Wright
    February 27, 2017 at 5:06 pm
    do they work if you change preview to 1/4 resolution?
  • Sander Somma
    February 27, 2017 at 5:08 pm
    No, the preview does not change anything. Scrolling on timeline is fine tough, like I mentioned.
  • Chris Wright
    February 27, 2017 at 6:01 pm
    hmmm. are you mac? 10.12.3 MacOs fixed some premiere issues
    here’s some more ideas:
    Choppy playback in Premiere Pro
    https://forums.creativecow.net/thread/3/974536#975716
