Activity › Forums › Adobe Premiere Pro › Premiere Pro 2017.0.1 Laggy “Play” playback – GTX 1080, SSD Raid, Xeon E5-2630 2.20 GHz (2 processors)
Chris Borjis replied 9 years, 6 months ago 7 Members · 16 Replies
Ann Bens
February 28, 2017 at 12:25 amHave you considered updating to 2017.0.2?
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional -
Andy Patterson
February 28, 2017 at 4:56 amDid it used to work and now it does not? Could it be the Nvidia display card drivers?
Sander Somma
February 28, 2017 at 11:00 pmI will be checking if I can update to newer version. It did work before. Im not sure how and when this happened. I uninstalled and reinstalled, nothing. Today I uninstalled again and also used Adobe Cleaning tool but wont install before I get newer version. Still tough it should never use 100% to freezing Premiere with such powerful CPU.
Other formats, full hd wont even play perfectly.
Sander Somma
March 1, 2017 at 6:48 pmGreetings. Clean install, of new version 2017 1.02. It got better by 15%. There has to me some massive bug or failure somewhere.
Chris Borjis
March 2, 2017 at 1:30 amIs it set for OpenCL or CUDA acceleration?
I would switch to OpenCL if it is currently CUDA or vice versa (something to try)
I had awful lag with 1080p AVC multicam with CUDA but switching to OpenCL solved it.There was some buggy cuda stuff going on recently.
If that does nothing try disabling mercury transmit if it is enabled.
That might help too.Nice system by the way!
