Activity › Forums › Adobe Premiere Pro › Pre Pro Scratch disk write protected or unavailable????
Peter Humble replied 7 years, 10 months ago 38 Members · 41 Replies
Nate Priest
April 24, 2013 at 6:25 pmOh my god, thank you!!! I just spent two hours troubleshooting an issue that seemed to be much more complex, but in the end it was just a backslash in the project name. This seems like a very silly issue, but I’m thrilled that you led me to the solution. Thanks again.
Cris Cazor
June 22, 2013 at 6:03 pmGENIUS!!!!!!!!!!!!!!!!!
Took me less than 5 secs to do this, instead of frying my brain and wasting more time.
THOMAS YOU FRIGGING ROCK!
ThanksCris
Jo Slater
October 25, 2013 at 10:08 amI fought with this issue for two days on a project. Premiere wouldn’t let me render or export. i tried clearing all temporary files and rendered files tried moving the whole project onto a different mac.
In the end all i needed to do was change the name of my project and take out this character ” / ”
Problem solved!
Jo Slater
SMR Creative -
Sherri Eng
December 15, 2013 at 12:04 amWhat was the solution to this issue for those of us with a PC? I am using Adobe Premiere Pro CS6 on Windows 7. Thanks.
Sherri
Stefano Bianchi
February 15, 2014 at 8:09 pmThank you very much, that would seem to be the solution! No slash (“/”) symbol in the filename.
All the best, and ciao from Italy!
(MacPro, OSX10.6.8, Adobe Premiere CS6). -
Andy Gardner
April 10, 2014 at 12:25 pmIn Windows, right click the folder you want to use as your scratch disk. In the Attributes section, click to clear the blue box next to “Read Only” and you should be good to go. This happened to all my folders after a windows update.
Jamie Martina
May 2, 2014 at 11:33 amThere is no “Attributes” section in the list of choices when I right click. What system are you running?
Jamie Martina
May 2, 2014 at 12:08 pmOk, so I see where you’re talking about. I unclicked the blue box, but it goes back to blue as soon as I hit “Apply” and “Ok”. Also, all my folders in all my drives are checked blue…..but I only have the issue with one project.
