Activity Forums Adobe Premiere Pro PPro CS4 won’t render my sequence
  • PPro CS4 won’t render my sequence
    Posted by John Stanowski on August 4, 2009 at 5:26 pm
    Everytime I send a sequence to Media Encoder, it just sits there. And sits and sits, etc. At the bottom it just says “Loading “Gleaner_Shoot.prproj”.
    I’m using a 2008 Mac with 8 cores with 16 gigs of ram.
    My footage came from the Canon HV20. I have clips at both 24p and 1080i.
    I’m setting up my sequences to match the clips I’m placing in them.
    One thing of note is I’m really only using 3 looong clips. Since CS4 doesn’t do scene detection well. I opted to instead make subclips from the long clips and use those. 2 of them are about 30 minutes long and one is nearly an hour. Could this be the problem?
    Thing is, this happens even when I do a 1-minute sequence test.
    It even happens when I try to use a test sequence which contains only audio.
    I’ve tried outputting to quicktime and MPEG 2. I was careful to set the export settings to match the sources.
    After a long wait, Media Encoder gives up and I get a warning icon in the status column. It says this:
    – Source File: /Users/johnstanowski/Library/Caches/TemporaryItems/Gleaner_Shoot.prproj
    – Output File: /Users/johnstanowski/Desktop/THURDAY.mov
    – Preset Used: Custom
    – Video:
    – Audio:
    – Bitrate:
    – Encoding Time: 00:11:07
    Tue Aug 4 13:19:39 2009 : Encoding Failed
    Could not read from the source. Please check if it has moved or been deleted.
    I usually use After Effects so I’m not really up on Premiere that much, but I’ve used it a good bit in the past and never came across this problem.
    Any ideas?
    P.S. I just closed the whole project and started a new one with simple DV footage… and the same thing is happening. I’m beginning to think there’s a plugin or something messing with Premiere Pro. I think it’s a plugin because this problem is happening here at work and also at home.
    John Stanowski replied 16 years, 10 months ago 4 Members · 6 Replies
  • John Stanowski
    August 4, 2009 at 6:39 pm
    Problem Solved. After more investigation I found out the problem was indeed the plugin. Seems CS4 now likes to store all of the plugins in one central location. And this confuses Adobe Media Encoder. I have a ton of After Effects plugins and i found that many of them were saved in this new central location. I simply moved them to the AE plugins folder and now Premiere works fine. Kinda ridiculous this happened to begin with though. I lost two days.
  • Jon Barrie
    August 4, 2009 at 10:20 pm
    Are you running the latest updates?
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • John Stanowski
    August 4, 2009 at 10:28 pm
    Yes, I always update the software and the OS as soon as they become available.
  • Albert Hoekstra
    September 3, 2009 at 11:51 am
    Where can I find the central location? Thanks!
  • Drew Jensen
    November 23, 2009 at 7:14 pm
    I’m having the same problem and nothing seems to work. The difference for me is that I have no 3rd party plug-ins and it just started about 1 week ago not working. Just in case, where are the plugins located?
  • John Stanowski
    November 23, 2009 at 10:00 pm
    On a Mac sometimes plugins will install into this folder:
    user/Library/Application Support/Adobe/Common
    Not sure exactly where this would be on a PC but I imagine it’s very similar.
