Activity › Forums › DaVinci Resolve › Poor performance out of a kick ass system
  • Poor performance out of a kick ass system
    Posted by Sascha Haber on July 3, 2012 at 10:01 am
    Hi guys,
    my first post in this part of the forum , and I am little puzzled.
    So far I only had the pleasure setting up Mac systems, now I am dealing with a PC and its the usual horror .
    The thing is, this system is supposed to be really really good.
    Its a GlobalStor with plenty of PSU power, 24 disks two Areca controllers and a Quadro6000 with SDI.
    Its our Scratch workstation and so far its running fine.
    So we bought a Quadro 600 for the main display.
    I put that and use the Quadro6000 as GPU….bummer….the results are like using a Quadro4000
    On CUDA Z I am getting around 1050 Gflops…as it should be.
    So i now got a GTX 580 from Gainward with 3 gig to test that.
    Same story .. Candle test gives me 5 !! nodes before the speed drops.
    Thats 2 nodes more than the 6000 and less than I have on my Mac with 120/470 cards.
    So a question for the people using cross platform systems.
    What to expect ?
    I can clearly see the 580 is like 60% faster than the Quadro6000 , in spite of it being mentioned the other way round in the config guide.
    But still the performance is far from being usable in a feature production.
    Could the Quadro 600 be the problem ?
    We are thinking Cubix already, but first I would like to get to comparable results using on board possibilities.
    So if anyone made a test with the same can in Mac AND Windows, please share.
    A slice of color…
    DaVinci 8.2.1 OSX 10.7.2
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    ICA Instructor
    https://www.icolorist.com/Sascha.html
    Alpagut Develioglu replied 12 years, 8 months ago 14 Members · 41 Replies
  • 41 Replies
  • Pepijn Klijs
    July 3, 2012 at 10:42 am
    Could you post the standard candle test again? been searching for that… This morning I posted a benchmark request, also in this forum. Maybe you would like to participate?
    Editor/Colorist, Amsterdam, The Netherlands
    http://www.pepijnklijs.nl
  • Sascha Haber
    July 3, 2012 at 11:28 am
    Sure, no problem.
    https://www.yousendit.com/download/QlVoWWVpVnNCMTZwSHNUQw
    You dont even need to replace the footage.
    Just press play, look at the numbers, press stop, change to a higher version, press play…and so on.
    Here my numbers from the Mac Systems I was probing and the PC I have issues with right now.
    Mac_OSX_____Q4000-only_____285/120_____470/120_____2xQ4000-Cubix4/120
    PC_WIN_7____Q600/Q6000____Q600/GTX580________________________________
    V1_2 nodes_:_____23__________24__________24__________24 fps
    V2_4 nodes_:_____14__________24__________24__________24 fps
    V3_6 nodes_:_____10__________17__________22__________24 fps
    V4_12_nodes:______5___________9__________11__________12 fps
    V5_NR_4/30_:_____15__________24__________24__________24 fps
    V6_NR_3/30_:_____10__________14__________23__________24 fps
    V7 NR 2/30_:______5___________7__________11__________12 fps
    V8 NR 1/30_:______1___________2___________3___________4 fps
    A slice of color…
    RAID0 8TB
    Extreme 3D+
    ICA Instructor
  • Pepijn Klijs
    July 3, 2012 at 12:07 pm
    Thanks for the post. Unfortunately I think I will not be able to run the test with Resolve Lite right?
    I cannot even import the project.
    Thanks anyway…
  • Pepijn Klijs
    July 3, 2012 at 12:17 pm
    edit:
    Eventually I found how to open the project…
    My results:
    Hackintosh OSX – GTX 580 1,5GB + GTX 560 Ti 2GB – Resolve Lite 8.2.1
    v1: 24 fps
    v2: 24 fps
    v3: 24 fps
    v4: 17 fps
    I couldn’t test the versions with noise reduction because of the Resolve Lite limitations.
  • Sascha Haber
    July 3, 2012 at 12:29 pm
    Which card is used for what operation ?
    A slice of color…
    RAID0 8TB
    Extreme 3D+
    ICA Instructor
  • Pepijn Klijs
    July 3, 2012 at 12:30 pm
    My WIN 7 results – GTX 580 1,5GB + GTX560 Ti 2GB – Resolve Lite
    v1: 24 fps
    v2: 24 fps
    v3: 24 fps
    v4: 15 fps
    So almost zero difference between OSX and WIN, just 2 fps in V4.
    Sasha, I don’t completely understand your results. Are they for your mac configurations or for your win setups? I’m counting 6 setups, but just 4 testresults.
  • Sascha Haber
    July 3, 2012 at 12:37 pm
    Thats because they are the same…
    A slice of color…
    RAID0 8TB
    Extreme 3D+
    ICA Instructor
  • Pepijn Klijs
    July 3, 2012 at 12:50 pm
    GTX 580 GUI
    GTX 560 Ti GPU
  • Pepijn Klijs
    July 3, 2012 at 12:58 pm
    So, if I understand this corretly, your saying that Mac using Gt 120 and GTX 285 has an identical performance to a pc using Quadro 600 and GTX 580?
  • Sascha Haber
    July 3, 2012 at 1:15 pm
    Exactly… and thats totally FU.
    So maybe that Quadro 600 is the limiting factor.
    Or something on the mobo, we did a fresh install, same results.
    Thanks for letting me know some bigger numbers are possible.
    A slice of color…
    RAID0 8TB
    Extreme 3D+
    ICA Instructor
Page 1 of 5
