Activity › Forums › DaVinci Resolve › Poor performance out of a kick ass system
Alpagut Develioglu replied 12 years, 7 months ago 14 Members · 41 Replies
Pepijn Klijs
July 3, 2012 at 1:22 pmThta’s indeed weird and against expectation.
The only thing I can come up with now is to uninstall the decklink card as that one is known to act ‘funny’ on some mobo’s and in windows.
Editor/Colorist, Amsterdam, The Netherlands
http://www.pepijnklijs.nl -
Pepijn Klijs
July 3, 2012 at 1:26 pmI also put this in the debug screen:
LsManager.3.NumGPUs = 2
Might help…
Peter Berg
July 3, 2012 at 6:26 pmHi Sascha,
Sorry you are having issues with your Windows system. But I feel your pain. I just built a Windows system and expected it to run great. But at first I was having major problems. Got a few fixed, and now I am just having minor problems. Although the performance isn’t as great as I thought it would be. I could try to run a performance test as well if it helps.
I did do a test where I took out my decklink card. My fps went up by 1 or 2, but nothing significant. I’m sure that was just because it wasn’t having to send out a video signal. How do you have the cards in your system? I found that by switching my Quadro 600 and the GeForce 580 the performance went up for some reason (both slots are x16 electrical slots).
I can get realtime playback now, but with only like 1 or 2 streams. Also I can’t get my panel (JL Cooper Eclipse) to be recognized. So yeah it’s still a work in progress.
Wish I could offer more help.. but I guess I feel your pain.
thanks,
Peter -
Juan Salvo
July 3, 2012 at 7:43 pmWhat motherboard are you using? Want to give us more specs on system config, and driver versions?
Colorist | Online Editor | Post Super | VFX Artist | BD Author
Dmitry Kitsov
July 3, 2012 at 8:40 pmWin7. X5690. 48GB. GUI: Qadro4000. GPUs: GTX580 x2
V1_2 nodes_:24
V2_4 nodes_:24 fps
V3_6 nodes_:24 fps
V4_12_nodes:24 fps
V5_NR_4/30_:24 fps
V6_NR_3/30_:24 fps
V7 NR 2/30_:24 fps
V8 NR 1/30_:9 fps -
Helge Tjelta
July 4, 2012 at 9:39 amHow did you manage… I’m on REsolve light here, latest beta and I only get Invalid FCP XML file…?
Helge
Pepijn Klijs
July 4, 2012 at 10:27 amYou must import the zip file, not unpack the zip file, then it works. You don’t need to replace any footage, apparently the test works without footage.
Good luck and let us know your result!
Robert Houllahan
July 5, 2012 at 2:02 pmI think you might have the GPU throttleded back due to the PCIe lane distribution and how the cards are installed. There are a limited number of lanes available on most MB’s and even though the slot might be X16 electrically it may run at X8 or X4 depending on what other cards are installed and where they are.
Can you post what make and model the board is?
-Rob
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.comMAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma. Light-Space CMS + Hubble
Sascha Haber
July 5, 2012 at 4:53 pmWell, I put both cards into a HP Z800 workstation today..
Exactly the same results.
5 nodes with a Quadro600 as UI and a GTX580 as GPU
3 nodes with a Quadro600 as UI and a Quadro6000 as GPUI tried all three 16X ports and only had those two cards in.
I am starting to think the Quadro600 as Ui might be the bottleneck.A slice of color…
DaVinci 8.2.1 OSX 10.7.2
MacPro 5.1 2×2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+ICA Instructor
https://www.icolorist.com/Sascha.html -
Juan Salvo
July 5, 2012 at 5:03 pmCan you put the q6000 as the GUI?
