Activity › Forums › Apple Motion › Please, help with stop-motion
Posted by Bensne on October 10, 2005 at 12:52 pmHow can I make stop motion animation smoother in Motion? Is there some way to blend the key frames between shots, perhaps? I’d appreciate any help. Thanks.
Kevlareditor replied 20 years, 11 months ago 6 Members · 10 Replies -
Walter Biscardi
October 10, 2005 at 12:54 pmShoot more in-between shots. The more frames of action you have, the smoother it will be.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Now editing “Good Eats” in HD for the Food Network
G5 Dual 2.0, AJA Kona 2, Medea FCR2X
Bensne
October 10, 2005 at 1:13 pmI have already shot the piece by taping 6 frames at a time with a Z1U. I was just wondering if I can make the motion smoother in Motion. There is some effect I found in Final Cut for stop motion animation, but it produces a sort of double exposure on screen that I am not really happy with. Any other suggestions?
Jim Kanter
October 10, 2005 at 4:26 pmAre you removing 5 of the 6 frames for each “frame”?
Also, more frames per second on playback will make for smoother motion (24 fps strobes more than 30)
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com -
Bensne
October 10, 2005 at 5:33 pmNo, I am not. The HDV Z1 has a setting on it for stop motion animation that tapes for 6 frames everytime the record button is pressed. I moved the objects progressively about 1″ after shooting it each time. As it is now the motion looks kind of decent in all of my shots. I would just like to make them a little more fluid. Thought there might be a something in Motion or some other program that might help accomplish this.
Bill Mcguire
October 10, 2005 at 5:43 pmYou might try one of the Morphing programs (Morphage…$80, Morph X… free). I also remember a program that would automatically add frames in between (you could specify the number of fill in frames) but I can’t remember the name of it. Perhaps someone else can. If you find out, let us know..
Doyle Rockwell
October 10, 2005 at 8:27 pmC’mon, Walter, you can do better than that 😉
Using an optical flow-based retimer can help smooth this stuff out a little, as well as letting you add motion blur to stuff that’s supposed to be moving fast. RE:Vision Twixtor and Realviz Retimer are a couple, as well as the new time-warping stuff in Shake 4.
To use that method, though, you’ll need to go into your clip and separate it out into unique frames, reducing the duplicates. i.e. if frames 1-6, 7-12, 13-18, 19-24, and 25-30 are all groups of six-frame dupes, that, together, form one second (30fps), then you make a new image sequence of just 5 unique frames: 1,7,13,19,25. You can then use the above-mentioned tools to stretch that 5-frame dealie back out into 30. Extrapolating 25 new frames from 5 will be fairly heinous, though, so you might want to just reduce your sequence down to 15 frames to keep the extrapolation smoother (only doubling to get back to 30).
Off-topic: Walter, if you’re editing GE in HD, when do I get to watch it? I’m dying, having to watch AB do his thing in SD, tell those FN people to upgrade ASAP! (mmmm…acronyms).
Jim Kanter
October 10, 2005 at 8:32 pmIn Motion you can trim the clips to 1 frame each. You will want to modify the amount of change between frames if you do this.
You might also consider dissolves between the clips/frames (the cheap way to do an “optical flow”).
Jim Kanter,
Bensne
October 11, 2005 at 1:20 pmThank you for all your suggestions. I will let you know what works best for me.
Bensne
October 13, 2005 at 3:11 pmI have stuck with the Final Cut stop motion blur effect in the video filter menu. I altered the effects blur rate per frame, the amount of overlap, and disintegration. It has worked out very well for me. The motion is very fluid. Once again thanks for all of your input.
Kevlareditor
October 23, 2005 at 7:01 pmOne thing you can do to extract single frames is to take the clip into After Effects and re-time it at 1/6th it’s original length, and turn frame blending off. You should automatically pluck every 6th frame without manual editing. This is assuming that it records exacly 6 frames each time.
