Playing MKV
Posted by Paul Gregory on February 3, 2015 at 2:27 amI have read here several times that other codec’s can cause problems with Vegas Pro.
If I must play some MKV files is there any way to get Windows Media Player without causing havoc elsewhere. I only want to play them for a home network not to use any in Vegas for encoding?
Thanks in advance
Mike Kujbida replied 11 years, 7 months ago 5 Members · 6 Replies -
Russ Froze
February 3, 2015 at 4:23 amTry installing VideoLan Media Player all codecs are contained withing app and do not get installed or become available for use in other apps. IE Vegas
https://www.videolan.org/vlc/
Russ Froze -
Paul Gregory
February 3, 2015 at 4:43 amI’m just stating to set up home networking & have the cat cable now installed. Most of the files that I will wish to play on a media player are MKV because I can turn on/off subtitles. I know that VLC does this & I have it installed on my PC.
The reason that I’m asking about Windows Media Player is because I was told that this was best for sharing files on a Home network. If this is not the case I would like to get other recommendations?
Thanks in advance
Phil Peacock
February 3, 2015 at 10:21 amI use TVersity Media Server on my system and it seems to work a treat, without upsetting SVP.
Dave Osbun
February 3, 2015 at 7:08 pmPretty much every Windows system (if not all of them) already have Windows Media Player installed. Even if you update Windows Media Player it is not going to negatively affect Vegas Pro and its codecs.
Dave
Paul Gregory
February 4, 2015 at 3:14 amI think that some of the codec packs allow you to install just the codec’s that you need rather than all of them.
Thanks in advance
Mike Kujbida
February 4, 2015 at 3:18 amLike Russ said, use VLC.
Here’s a good guide from the AfterDawn web site supporting his answer.
How to play MKV files
