Playing AVI in sony vegas 10
Posted by Kayley Grace on October 27, 2011 at 12:59 amHi there,
Is there anyone that knows how I can play AVIs in Sony Vegas, When i go to import i get a codec error message and I’m not sure what to do.many thanks
kayleyJohn Rofrano replied 13 years, 8 months ago 3 Members · 23 Replies -
Steve Rhoden
October 27, 2011 at 1:17 amWhich version of Vegas are you using? and where were those
AVI’s you are trying to import originate from?Steve Rhoden
(Cow Leader)
Film Maker
Filmex Creative Media.
1-876-832-4956
https://filmex-creative-media.blogspot.com/ -
Kayley Grace
October 27, 2011 at 5:58 amHi Steve,
I am using Sony vegas Pro 10.0e (build 738)64-bit.I recorded a video using replay telecorder for skype which are saved on my hard drive as Video Clip (.avi)
Thanks Kayley
John Rofrano
October 27, 2011 at 2:24 pmYou have to realize that AVI is not a video format. It’s just a file container that can contain many different video formats. The video formats themselves are supported by CODECS. You are getting a codec error because the codec that is needed to decode the video format in order to play the AVI file is either missing or corrupt.
Use a tool like GSpot or MediaInfo to determine what codec the AVI file uses and then install just the codec that you need.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Kayley Grace
October 27, 2011 at 11:49 pmThanks John, I didn’t know that is what avi meant.
I have installed gspot and have checked the file and it says codecs installed under status and the codec is MPG4.What do I do now? Do i install a MPG4 codec.
Funnily enough the video that is working in vegas says Codec Status Undetermined under status and has it as a WMV3.
Many thanks for your help. Kayley.
Kayley Grace
October 28, 2011 at 12:09 amI also found a post where you suggested having a look to see if the video played in Gspot and what happened under the MS A/V 1 & 2 buttons. The video does play in Gspot.
When I click on the 1 I get the following message
Render OK. The following combination of filters was used:
(Src)–>>–(A)–>[AVI splitter ]>–(B)–>[Mpeg4 Decoder DMO ]>–(C)–>[video Renderer ]
(Src)–>>–(A)–>[AVI splitter ]>–(B)–>[MP3 Decoder DMO ]>–(C)–>[Default Direct Sound Device ]The audio codec is 0x0055 (MP3)
The video codec is MPG4 MS MPEG-4 v1Hope that helps in figuring out what is happening with the files when i try to import them.
many thanks Kayley.
Kayley Grace
October 28, 2011 at 12:45 amSolution found go to this thread and follow the instructions if you find yourself with a codec error.
https://forums.creativecow.net/thread/208/877493
Thanks for the extra support Steve and John I appreciate it.
John Rofrano
October 30, 2011 at 1:37 pmI would not recommend that fix. Renaming DLL’s in a product is NEVER a good idea. You don’t know what problems it could cause in the future and now you have an unsupported non-standard installation.
A better solution would be to install an MPEG4 codec for AVI like x264vfw. I’m not sure if this works in the 64-bit version of Vegas Pro. If not, I would use the 32-bit version of Vegas to render the files to MJPEG because editing MPEG4 in an AVI container is not recommended.
~jr
Kayley Grace
October 30, 2011 at 10:50 pmThanks John for the suggestion. I still have the old dll file so i can always change it back to the original one if I need to.
I’ve also read posts that installing codecs is a bad idea because it changes your whole system and you don’t know what the new codec is going to do.I’m not really sure which path is the best way to go, this one seems to have worked for now and I appreciate your advice. If I have any issues I’ll remember to change it back look at installing the codec you suggested.
Fingers crossed it will all work fine now.
John Rofrano
October 31, 2011 at 10:39 am[Kayley Grace] “I’ve also read posts that installing codecs is a bad idea because it changes your whole system and you don’t know what the new codec is going to do.”
What you have read is that installing a Codec-pak is a bad idea. This has nothing to do with installing individual codecs which is *exactly* what you should do. Codec-paks contain 10’s of codecs that install together whether you need them or not and it overlays the good codecs that ship with Vegas with free alternatives that may not perform as well or my not work at all with Vegas. You should never install a codec-pak. You should always just install the one codec that you need for a particular file format.
If it’s working for you that’s great. When the next update to Vegas comes along and you install it, you’re on your own for support. Who knows how it will react to not finding the correct DLL’s it expects. This could prevent you from getting the necessary fixes installed.
~jr
Kayley Grace
November 2, 2011 at 12:46 amThanks John I didn’t realise that. I will change the file and install the codec you suggested. I appreciate the advice.
Cheers Kayley.
