Activity › Forums › DaVinci Resolve › Playback stalls on Network Drives
Joe Gill
September 10, 2013 at 10:52 pmTerence –
What was the resolution on this? Did you hear back form BM? They are usually very prompt about these kinds of things.
Joe
Joe Gill
Terence Curren
September 11, 2013 at 12:22 amHaven’t heard back from them. It appears that the issue doesn’t happen on Macs. So it’s a network mounted drive on Windows that is the problem.
Terence Curren
http://www.alphadogs.tv
http://www.digitalservicestation.com
Burbank,Ca -
Joe Gill
September 11, 2013 at 12:24 amThen do bug Facilis – they will get back to you at some point shortly. I am looking at using Facilis Storage and this is a real sticking point for us…
Joe Gill
Terence Curren
September 11, 2013 at 12:27 amFacilis is looking into it. I suspect it is going to come down to something Resolve is doing with network attached drives in Windows.
For the meantime, our workaround is to use the Terrablock drives in single user mount mode instead of MultiWrite.
Terence Curren
Burbank,Ca -
Ericbowen
September 12, 2013 at 4:06 pmWhat is the Network adapter driver and version for the Windows systems. Please also include date info.
Eric-ADK
Tech Manager -
Terence Curren
September 12, 2013 at 5:48 pmAtto FC-41ES
Windows 7 Pro SP1
Z-800
Resolve 9.1.5
What date?
Terence Curren
Burbank,Ca -
Ericbowen
September 12, 2013 at 5:59 pmDriver date for the Fiber network card.
Eric-ADK
Tech Manager -
Terence Curren
September 12, 2013 at 6:03 pmThe driver version is 2.66 the flash is July, 28th, 2010: which is the Facilis approved driver and firmware.
Terence Curren
Burbank,Ca -
Ericbowen
September 12, 2013 at 6:51 pmYep that is the latest one since it has been discontinued. Outside of checking for advance settings to streamline the network processing, I cant see a way to fix this on the adapter side.
Eric-ADK
Tech Manager -
Terence Curren
September 12, 2013 at 6:56 pmWell, we are using the same adapters on Macs on the same Terrablocks and they don’t have the same issue. 🙁
Terence Curren
Burbank,Ca
