Activity Forums DaVinci Resolve Playback stalls on Network Drives
  • Playback stalls on Network Drives
    Posted by Terence Curren on August 27, 2013 at 4:55 pm
    When we run Resolve on a Facilis Terrablock with Multwrite drives (appears as network drives like Unity or ISIS), we get a stall at each new shot on playback. If we struggle through a few times, it seems to cache somehow and then will play without hiccuping.
    The same volume mounted as a single write drive (appears as direct attached storage) has no issues.
    Bandwidth tests show no issues either.
    I have talked to another house who had similar issues with renders stalling on ISIS.
    Is there a trick to using a network shared drive with Resolve?
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
    Ericbowen replied 13 years ago 6 Members · 25 Replies
  • 25 Replies
  • Ericbowen
    August 28, 2013 at 3:23 pm
    Sounds like network latency. How are you connected to the network on the client systems and at the server?
    Eric-ADK
    Tech Manager
  • Terence Curren
    August 28, 2013 at 3:24 pm
    4 Gig Fibre on both sides.
    Terence Curren
    Burbank,Ca
  • Eric Hansen
    August 28, 2013 at 3:27 pm
    what are the source codecs and resolutions?
    Eric Hansen
    Production Workflow Designer / Consultant / Colorist / DIT
    https://www.erichansen.tv
  • Terence Curren
    August 28, 2013 at 3:33 pm
    DNxHD 175 23.98 1080Psf.
    Not a very demanding stream. Again, the exact same volume mounted as a “single-write” drive (meaning it appears as a regular volume not a network shared drive) works fine. So that leads me to believe it’s not bandwidth issues. I was wondering if Resolve treats a network mounted volume differently than a direct attached volume.
    Terence Curren
    Burbank,Ca
  • Eric Hansen
    August 28, 2013 at 3:41 pm
    I haven’t had issues over unmanaged ethernet SAN. i wonder if its a permissions issue since it sounds like you’re switching between locked and unlocked volumes. Maybe Resolve has an issue with Read-Only media (which seems really strange to me). Are you writing DNX back to the volume, or something more metadata intensive like DPX? Might want to repost over in SAN networks and see if Jim from Facilis has any answers.
    e
    Eric Hansen
  • Ericbowen
    August 28, 2013 at 3:48 pm
    The Network drivers and OS treat the data differently between network volumes and Direct Attached volumes. There are several differences which mostly revolve around latency. Latency and throughput are different. You can have a network that pushes a 1GB/s a sec however if the latency is to high the playback will still interrupt. If you have software layers for file writing that allow multiple access then that will also add latency to the data stream. Davinci ram previews so when you first hit play Davinci’s player is building buffers into the ram. Once the buffers are built then the preview will be seemless because the network latency is no longer involved. The Data is local. That is why it stops at each clip when you first start playback and then will play fine the next time.
    Eric-ADK
    Tech Manager
  • Juan Salvo
    August 28, 2013 at 4:04 pm
    I agree with Eric, this is a latency issue and is due to the way the OS is handling the network share. Some program will realize a file system is not direct attached and preread the a clip ahead so as to avoid dropping frames due to latency. Resolve definitely prefers direct attached media.
    color/post/workflow
    https://JuanSalvo.com
  • Terence Curren
    August 28, 2013 at 7:52 pm
    Well, this seems to match what our tests are showing. We have been running several other apps for years on the MultiWrite (network attached) Terrablock volumes for years with now issues.
    I just wonder what Resolve is doing differently?
    Terence Curren
    Burbank,Ca
  • Bob Zelin
    August 31, 2013 at 11:40 am
    I disagree with my esteemed colleagues
    While latency is an issue with the 1gbe systems used by mr Hanson, mr boden,mr salvo, and myself,
    You are using a facilis with 4g atto fc41es fibre cards in server and client, connected to a qlogic switch.
    You are trying to play a single 20MB/sec stream on a system that can do 200MB/sec per client.
    IMHO you do not have a latency issue.
    Facilis needs to download resolve lite and do a simple import and playback of a DNX file. The download is free for them. This is local to resolve. You won’t get help from BMD on this.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    maxavid@cfl.rr.com
  • Terence Curren
    August 31, 2013 at 1:25 pm
    Thanks Bob!
    Terence Curren
    Burbank,Ca
Page 1 of 3
