Activity › Forums › Apple Final Cut Pro Legacy › PhotoJPEG vs Blackmagic 8-Bit Uncompressed
Posted by D on June 15, 2005 at 3:21 pmHey Gang,
Does anyone use Photo JPEG (100%) as an offline codec that can compare it to their experiences using Blackmagic 8-Bit Uncompressed in terms of RT/Timeline responsiveness with trimming and overall look on a broadcast monitor?
How does it stack up in the real world?
Cheers,
-D
Matt Sandström replied 21 years, 3 months ago 5 Members · 28 Replies -
Graeme Nattress
June 15, 2005 at 4:13 pmI’d not use PhotoJPEG100% as an offline codec as it’s 4:4:4 RGB. Use PhotoJPEG75% instead as it’s Y’CbCr at 4:2:2. Visually, it’s excellent.
Graeme
– http://www.nattress.com – Film Effects for FCP
D
June 15, 2005 at 4:41 pmHey Graeme,
Love your FCP plugins by the way! I am currently working in 8-bit 4:2:2 uncompressed all the time. Judging from some of the Tests I’ve seen (ie. One River Media) Photo JPEG seems to stack up very well. But I want to know how the RT etc. is in comparison to 8-bit uncompressed. Using it at 100% (4:4:4) shouldn’t be an issue with an Xserve RAID running at 280mb/sec read 180mb/sec write. or will using the different color space introduce luminance shift?
Cheers,
-D
D
Cheers,
-D
D
Cheers,
-D
D
Cheers,
-D
D
Cheers,
-D
D
Cheers,
-D
Bryce Whiteside
June 15, 2005 at 5:02 pmNah, nah, nah, nah, nah, nahhaaa…
Bryce
Don’t worry Mr. B. I have a cunning plan…
PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
Final Cut Pro HD
DVD Studio Pro 3
Motion -
Graeme Nattress
June 15, 2005 at 6:03 pmWell, because your video is 4:2:2, going to 4:4:4 is not going to add any quality, and the actual amount of compression is the same, other than that difference, between 75% and 100%, so there’s no real advantage to the 100% version, and as you say, could introduce luma issues.
However, Apple have not RT enabled PhotoJPEG codec beyon 35% and small frame sizes for it’s Offlilne RT modes. This is totally evil on the part of Apple. You’ll therefore get more RT on your uncompressed 8bit video.
Graeme
D
June 15, 2005 at 6:18 pmHey Graeme,
That’s what I was affraid of… The problem I am having now, which is why I was considering using another codec, is that using Blackmagic 8-bit uncompressed leads to larger project files (over 12megs). FCP 4.5 has a really bad bug with large project files which causes stutter/slow down in the timeline when trimming/moving clips. If I start a new project with just a few 8-bit clips in it things move like butter and RT is actually quite good.
I can’t believe Apple let a bug like that go unfixed in 4.5 especially with the push for “professional” moniker with guys like Walter Murch ‘coming out’ in favor of FCP. The move to FCP 5 scares me after reading some of the FCP 5 horror stories on The Cow…
Cheers,
-D
