Activity Forums Adobe Premiere Pro Peak file problem: Not resolved!
  • Peak file problem: Not resolved!
    Posted by Ron Pestes on June 26, 2012 at 8:44 pm
    I am getting crashes during import of Sony EX .mov files into PP during the creating peak file portion of the import. Sometimes it works but most of the time the computer will crash at some point when the yellow bar indicates that a peak file is being created. I am using a Caldigit VR via esata or FW 400 connection into a Dell M6600 with 16 gig of RAM, 2820 processor and Windows 7 Pro. I called Adobe support and they deleted the Cache and Media Cache files and created new ones as well but this only helped for about 5 clips then I had the same problem. They then said that it is because my external drive is not fast enough but as I said I am using a Caldigit VR with esata with 7200 rpm drives so I don’t think that is the problem. I don’t have a problem if I copy the files to the C drive but that is obviously not a good editing option. What can I do?
    ronpesteshdvideo.com
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    Dell M6600
    Adobe CS6 Production Premium
    Ron Pestes replied 13 years, 10 months ago 1 Member · 1 Reply
  • Ron Pestes
    June 27, 2012 at 1:51 am
    Also, this same setup worked just fine last week on the same files.
    Sony EX-3
    MacBook Pro
    Dell M6600
