  • Posted by Cromwell Karlon on February 22, 2006 at 7:43 am
    Well I just recently read that using both the PCA card slot on my powerbook a long with
    the fire 800 port on the other side will render better results when using FCP.
    My only question is which card should I purchase and why?
    Shane Ross replied 20 years, 7 months ago 4 Members · 6 Replies
  • Debe
    February 22, 2006 at 8:23 am
    Officially, it’s a PCMCIA card, but please don’t ask me what it actually means.
    What it gets you is an extra pathway. If you get a firewire bus card, you get an extra firewire bus. That may help alleviate throughput issues when capturing or outputting to tape. If you go with a SATA bus card, you can connect external SATA drives and can avoid the pitfalls of using firewire drives for media storage altogether.
    deb
  • Cam Trejo
    February 22, 2006 at 3:14 pm
    I’ve been using the Lacie Card for about a year now with great results.
    Cameron Trejo
    East Valley Productions
  • Cromwell Karlon
    February 23, 2006 at 3:38 pm
    Pitfalls?? I thought firewire was solid? That’s news to me, and I guess I’ll be going with the lacie brand.
  • Debe
    February 23, 2006 at 6:46 pm
    Firewire can be solid for some…but it’s not consistently solid for all, and therefore, Apple doesn’t recommend the use of firewire drives for media.
    And neither do many of the folks here. Some do, many don’t. Some say they’ve been using FW drives for years and have never has a problem. Some can’t get sustained throughput and drop frames incessantly and the only solution is to get the media off the FW drive.
    Brands also have fans and naysayers. If you’re interested, do a search of LaCie here and see what the general consensus is. Also try ProMax. Then there are the ones who recommend you buy bare drives from a place like zipzoomfly.com and an enclosure from a place like wiebetech.com and and build your own.
    debe
  • Cromwell Karlon
    February 27, 2006 at 7:24 am
    Client has a 2.7 powermac… and they have just about run out of harddrive space… So they just ordered 2 maxtor sata drives 400gig each.
    Turns out the Mac is already maxed out in terms of adding
    more harddrives… So what should I do?
    Buy a Sata card?
    If so which one?
    And I would also need harddrive enclosure… Which one?
    What other options do I have?
  • Shane Ross
    February 27, 2006 at 8:50 am
    Please post a new topic. You are asking this question in a topic related to Powerbooks.
    Shane
    Alokut Productions
    http://www.lfhd.net
