Activity › Forums › Boris FX Particle Illusion › Particle Illusion Crashes when I open an emitters properties?
  • Particle Illusion Crashes when I open an emitters properties?
    Posted by Joe Winko on November 7, 2020 at 8:29 am
    I’m having a problem with particle illusion. it crashes when i try to open an emitter’s properties after i put it on the stage. is there anyway i could fix it so i could edit the emitters properties? please help.
    im using particle illusion version 3.0.2
    Joe Winko replied 4 years, 10 months ago 3 Members · 6 Replies
  • Alan Lorence
    November 7, 2020 at 11:17 pm
    Is it every emitter or just a specific one?
    Try the new Particle Illusion standalone app from BorisFX.
  • Francois Blawat
    November 8, 2020 at 5:50 am
    <Joe>
    I found this info under my pi3.0.4 program. Hopefully this helps.
    When particleIllusion won’t start (or crashes at startup):
    1) Try the “reset default settings” in the Start – Programs – particleIllusion 3.0 – troubleshooting menu.
    If that doesn’t work:
    2) Try “run with software rendering” in the Start – Programs – particleIllusion 3.0 – troubleshooting menu.
    If that doesn’t work either,
    3) Restart your computer. (You’d be amazed how many times this fixes “strange” problems.)
    If software rendering does work, then you need to get updated video drivers from your video card manufacturer’s website.
    Francois
  • Francois Blawat
    November 10, 2020 at 1:15 am
    Try this older thread to see if the problem is with the Emitter. https://creativecow.net/forums/thread/pi-3043-crashing/
    Hopefully you have a backup of this located under your library_backups folder of the pi3 install.
    PI 3.0.4.3 Crashing
  • Joe Winko
    November 26, 2021 at 12:35 pm
    it’s not from that one emitter. it happens with all the emitters. im still havent this issue
  • Joe Winko
    i tried those & they didnt work
  • Joe Winko
    November 26, 2021 at 12:37 pm
    it’s every emmitter. i didnt want to use the new particle illusion. the older one that im using has specific emmitters that arent compatible with the new version.
